RE: Content of single test case as printable version
Christian Petzoldt, modified 11 Years ago.
Youngling Posts: 2 Join Date: 2/17/10 Recent Posts
is it possible to upload an image file to an existing or a newly added test case (on test case properties page, not as an attachment)?
My intention is to use an image file which is showing the test setup for the respective test case and - for documentation purposes - to have the possibility to export/print single or all test-cases as PDF file (content: description, steps and test setup).
Christian
Hi Christian,
first of all thank you for your feature request. As we understand your request, you want to have the attached file visible on the test case properties page without clicking on the download button of the attachment. This is not possible at the moment. We splitted the test case details into several tabs to preserve the clarity of the page, but we will discuss your suggestion with our usability team.
Tobias
Hi Tobias,
okay, thanks for the information.
Christian
Hi Christian,
the generation of a test plan document (containing details about all tests of a test plan) is already part of our roadmap, (tracked as KLAROS-409 - Create a Test Plan Document). Our current planning schedules this for the 2.7 release, so please have some patience here.
The idea to inline attached graphics sounds compelling enough to provide a solution there, but this will require some groundwork to be done beforehand.
Thanks for your input, I keep you posted on any progress here!
RE: Content of single test case as printable version (Answer)
Hi Christian,
as of Klaros 3.4 the Enterprise Edtion contains print pages of test cases, test suites, test results and test suite results.
