Unable to Run Single Case or Run Test Plan - Klaros Test Management - Forum - Klaros Test Management
Patricio Aguilera, modified 12 Years ago.
Youngling Posts: 3 Join Date: 2/8/10 Recent Posts
I am having a look at the 2.4.4 Community version and am trying to execute test cases.
When I select Run Single Test Case or Run Test Plan and choose an action, I get a blank pop up window. It shows where an image or object should be, but there is nothing selectable there.
I am running this on Win2K8.
I have attached the Tomcat log and screen shots.
-Thank you-
Patricio
-Thank you-
Patricio
RE: Unable to Run Single Case or Run Test Plan
Hi Patricio,
thanks for reporting your problem, it seems you are missing the Adobe Flashplayer plugin in your browser, could you please check if you have it installed?
Youngling Posts: 3 Join Date: 2/8/10 Recent PostsTorsten Stolpmann:
Hi Patricio,
Hello Torsten,
I did not have the Flashplayer plugin installed on the system. Earlier today, it had been a clean install. I installed it and the window displayed the steps as I had hoped it would. Thank you for the pointer. Do you know if that will be noted in the documentation as a requirement for the program?
RE: Unable to Run Single Case or Run Test Plan (Answer)
Jedi Council Member Posts: 778 Join Date: 2/12/09 Recent PostsPatricio Aguilera:
Hi Patricio,
good to hear that this solves your problem. You are right about the lack of documentation for the browser requirements.
Since we will replace the Flash based client with a JSF based solution in the upcoming version 2.5 this requirement will drop anyway, so please excuse that we will not mention it there
Hello Torsten,
Heh. That works for me. Thank you for your help.
-Thank you-
Patricio
-Thank you-
Patricio
Hello Patricio,
my pleasure, this FAQ entry will hopefully others with the same problem until 2.5 is released.
