Klaros-Testmanagement version 2.4.4 released - Klaros Test Management - Forum - Klaros Test Management
Release Notes for Klaros-Testmanagement version 2.4.4:
development projects.
manually executed test cases.
Version 2.4.4 - 2010-02-03:
Version 2.4.3 - 2010-01-28:
Version 2.4.2 - 2010-01-28:
[KLAROS-656] - Exception when logged in as manager and searching for users on an empty database.
[KLAROS-654] - Out of sort memory error when refreshing tables with revisionable objects too often
[KLAROS-639] - Mispelled RTF message properties in the default message bundle
Version 2.4.1 - 2010-01-08:
[KLAROS-638] - NullPointerException on the page to create issues if the jira project ID is wrong
[KLAROS-632] - Description and summary are not rendered in the single test run report
[KLAROS-630] - The Project selection and project maintain pages still allow to filter after the JIRA ID
[KLAROS-629] - PDF icon changes to XML icon on the Test Run History Report page
[KLAROS-623] - The tooltip for the assign test cases to a test plan is not correct anymore
[KLAROS-636] - Add the possiblity to repair the database after a crash
[KLAROS-635] - Increase the business code length for test case results, test plan results and test runs
[KLAROS-378] - Imprecise error message when unable to start a test case/test run
Version 2.4.0 - 2009-12-07:
New features:
[KLAROS-586] - Support the assignment of test plans to SUTs.
[KLAROS-585] - Allow the cloning of test plans.
[KLAROS-531] - Support Trac as a issue management system alternative.
[KLAROS-616] - The validate URL button has no effect if the loglevel is set to high.
[KLAROS-615] - The validate URL button in the configuration of issue management systems does accept too much urls.
[KLAROS-611 - Not closing the Autoupdater thread prevents proper tomcat shutdown.
[KLAROS-603] - The dropdown fields on the test case details pages are not aligned with the other input fields.
[KLAROS-601] - Nullpointer Exeption when searching for an empty dropdown field.
[KLAROS-598] - The username cannot be edited.
[KLAROS-589] - Error pages broken, if user is not logged in.
[KLAROS-588] - When the selected project is deleted, switching to the default project does not work correctly.
[KLAROS-583] - Unable to log in after changing admins username.
[KLAROS-555] - The Continue Button does not vanish after test continuation completion.
Changes:
[KLAROS-613] - Preallocate the description and environment field with the information of the test run.
[KLAROS-605] - Make the SUT column in the maintain test plans overview page editable.
[KLAROS-582] - Put klaros-favicon into installed tomcat.
[KLAROS-578] - The continue test run data table should show the number of already executed test cases.
[KLAROS-560] - Remove the unnecessary redraws and cache the graphics on the project dashboard page.
[KLAROS-521] - Explain the error message for missing JAVA_HOME JRE_HOME in the manual.
Version 2.3.3 - 2009-11-16:
New Features:
Version 2.3.2 - 2009-10-30:
Version 2.3.1 - 2009-10-23:
Version 2.3.0 - 2009-10-16:
New Features:
[KLAROS-462] - The JIRA-ID field should show pre-selected values from the JIRA-Instance, if available
Version 2.2.2 - 2009-10-07:
Version 2.2.1 - 2009-10-05:
Version 2.2.0 - 2009-10-02:
New Features:
Version 2.1.1 - 2009-09-10:
Version 2.1.0 - 2009-09-04:
New Features:
Version 2.0.4 - 2009-08-24:
Version 2.0.3 - 2009-08-21:
New Features:
Version 2.0.2 - 2009-08-19:
Version 2.0.1 - 2009-08-12:
Version 2.0.0 - 2009-08-11:
New Features:
Version 1.11.0 - 2009-05-29:
New Features:
Version 1.10.0 - 2009-05-11:
New Features:
Version 1.9.0 - 2009-04-24:
New Features:
Version 1.8.0 - 2009-04-17:
New Features:
Version 1.7.0 - 2009-04-03:
New Features:
Version 1.6.0 - 2009-03-27:
New Features:
Version 1.5.0 - 2009-03-20:
New Features:
Version 1.4.0 - 2009-03-13:
New Features:
Version 1.3.0 - 2009-03-06:
[NOTTRACKED] Updated docbook-xsl to
version 1.74.3.
Version 1.2.0 - 2009-02-27:
New Features:
67657 Kaiserslautern
Europaallee 10
Germany
Web: http://www.verit.de/
E-Mail: support@verit.de
Phone: +49 631 520 840 00
Fax: +49 631 520 840 01
New features:
Changes:
New Features:
New Features:
New Features:
New Features:
New Features:
New Features:
New Features:
New Features:
New Features:
New Features:
New Features:
New Features:
New Features:
New Features:
version 1.74.3.
New Features:
Europaallee 10
Germany
