Klaros-Testmanagement version 1.9.0 released
The Klaros-Testmanagement development team is pleased to announce the release of Klaros-Testmanagement version 1.9.0!
New features:
o Get the current version from the pom.xml and write it into a properties file in the 'src' folder of Klaros-Web.
o A JSF Exception is thrown if a generated report is empty.
o Remove the data table of all projects in the test run history view.
o The test run history should allow to choose a start and end date for the report.
o After password change the email-validator complains, if no email was given.
o The descriptions in the test plan report overflow the margin on the right hand side area.
o HTML Documentation is missing images in section 1.1.
Changes:
o The documentation should mention that the Vista install path should not be the Programs folder or that UAC must be disabled in this case.
o Update User Manual with the new Test Plan Report.
o Add an entry for the '.klaros' folder in the home directory that holds all property files.
o The installer should provide the latest release notes as a readme file.
67657 Kaiserslautern
Europaallee 10
Germany
Phone: +49 631 520 840 00
Fax: +49 631 520 840 01
