Klaros-Testmanagement version 1.6.0 released
Tobias Schmitt, modified 15 Years ago.
The Klaros-Testmanagement development team is pleased to announce the release of Klaros-Testmanagement version 1.6.0!
New features:
o The new role 'admin' were created to seperate the administrator from the manager
o Broken session handling for timed out sessions.
o Klaros-Core logging fixed
o Session Timeout while calling Klaros-Testmanagement for the first time.
o Test cases that were imported with the ImportServlet should be marked as automated test cases
o About-Link should be named Info in a german UI
Changes:
o Rearrange the import view to make it more useable
o The 'about' page should only be visible to a authenticated administrator
o A user should only be able to edit its own user and users who has a lower level
o The Label 'vorherigen' should use upper case spelling
o Add statistics of the test case results to the statistic page of Klaros
o The export formats for the report generation should be listed in upper case
o The first selected export format should be PDF
o Misleading label on testCaseEdit.jsp
o Improve the available users text for the demo on the login page
67657 Kaiserslautern
Europaallee 10
Germany
Phone: +49 631 520 840 00
Fax: +49 631 520 840 01
