How to change the fiels in the Test Run History report - Klaros Test Management - Forum - Klaros Test Management
When I generate a Test Run History report I get <System Under Test: SUT00017>, but I want to get the name of <SUT00017>, for example: <System Under Test: Firmware version 1.6.10>. Is it possible?
Thanks in advance
Angel Hidalgo
Thanks in advance
Angel Hidalgo
RE: How to change the fiels in the Test Run History report
Hi Angel,
it is currently not possible to show the SUT name in the Test Run History report, but we will add your suggestion as an improvement to our issue tracking system. The Test Run History report is not user editable, but you may take a look into our documentation (http://www.klaros-testmanagement.com/files/doc/html/User-Manual.CustomReport.html#User-Manual.CustomReport.Create), which explains how to create and edit the preconfigured user definable reports in Klaros-Testmanagement.
We have also recently released a report tutorial (http://www.klaros-testmanagement.com/files/tutorial/html/Report.Tutorial.html). This step-by-step guide explains how to create your own extensive reports for Klaros-Testmanagement.
