RE: View status of testcase result also in Define/execute pane
I'd requests a feature wich I miss now since we started to use Klaros. In the define pane you can see, that a single testcase has been executed at least once (lock symbol on the left side, delete button disabled). Where I totally miss this kind of visible marker is in the execute window. From my point of view it would make absolutely sense to have the latest status also there. At the moment you have to go first in the evaluate pane to see in the testcase section, which testcase is noticed there with an execution result. From there you can guess, which testcases are still open to be executed. But if you have about 100 testcases you'll get nuts so look for those open testcases.
Regards, Thomas
Hi Thomas,
I agree - this information is lacking there.
Albeit Evaluate / Test Case Results shows prior execution information it is only available for test cases that have yet been executed. As you can see in the attached screenshot this is now implemented towards 4.1.4 (KLAROS-2183).
Thanks for your suggestion!
