RE: Klaros 3.8.3 - Tomcat / Klaros shut down randomly - Klaros Test Management - Forum - Klaros Test Management
Jerome Sheed, modified 11 Years ago.
Youngling Posts: 4 Join Date: 10/29/13 Recent Posts
I've installed Klaros 3.8.3 on Ubuntu 12.04 and set it to use a MySQL DB.
All is fine and Klaros is set to startup automatically at every boot.
HOWEVER once left for some time it becomes unaccessible, via both its login page and Tomcat's URL on localhost:18080
Any ideas on how I could troubleshoot and which specific logs to look at?
I've taken a look at the logs folder in the Klaros folder and I don't see anything specific.
I installed like this:
http://jerome.co.za/klaros-testmanagement-software-an-installation-guide-ubuntu-12-04-lts/
Jerome
Jerome
root@klaros:/opt/klaros/logs# cat catalina.2013-10-29.log
Oct 29, 2013 9:19:18 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
Oct 29, 2013 9:19:19 AM org.apache.coyote.http11.Http11Protocol init
Oct 29, 2013 9:19:19 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1690 ms
Oct 29, 2013 9:19:19 AM org.apache.catalina.core.StandardService start
Oct 29, 2013 9:19:19 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.32
Oct 29, 2013 9:19:19 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor host-manager.xml
Oct 29, 2013 9:19:20 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor manager.xml
Oct 29, 2013 9:19:20 AM org.apache.catalina.startup.HostConfig deployWAR
Oct 29, 2013 9:12:37 AM org.apache.catalina.core.StandardContext addApplicationListener
INFO: The listener "com.icesoft.net.messaging.DefaultMessageServiceContextListener" is already configured for this context. The duplicate definition has been ignored.
Oct 29, 2013 9:13:10 AM com.sun.faces.config.ConfigureListener contextInitialized
INFO: Initializing Mojarra (1.2_15-20100816-SNAPSHOT) for context '/klaros-web'
Oct 29, 2013 9:13:13 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory examples
INFO: Deploying web application directory docs
INFO: Deploying web application directory ROOT
Oct 29, 2013 9:13:13 AM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-18080
Oct 29, 2013 9:13:14 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:18009
Oct 29, 2013 9:13:14 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/130 config=null
Oct 29, 2013 9:13:14 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 42715 ms
Oct 29, 2013 9:14:44 AM org.apache.coyote.http11.Http11Protocol pause
Oct 29, 2013 9:14:45 AM org.apache.catalina.core.StandardService stop
Oct 29, 2013 9:22:20 AM org.apache.catalina.core.AprLifecycleListener init
Oct 29, 2013 9:22:21 AM org.apache.coyote.http11.Http11Protocol init
Oct 29, 2013 9:22:21 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 2017 ms
Oct 29, 2013 9:22:21 AM org.apache.catalina.core.StandardService start
Oct 29, 2013 9:22:21 AM org.apache.catalina.core.StandardEngine start
Oct 29, 2013 9:22:21 AM org.apache.catalina.startup.HostConfig deployDescriptor
Oct 29, 2013 9:22:21 AM org.apache.catalina.startup.HostConfig deployWAR
Oct 29, 2013 9:15:38 AM org.apache.catalina.core.StandardContext addApplicationListener
Oct 29, 2013 9:16:07 AM com.sun.faces.config.ConfigureListener contextInitialized
Oct 29, 2013 9:16:10 AM org.apache.catalina.startup.HostConfig deployDirectory
Oct 29, 2013 9:16:11 AM org.apache.coyote.http11.Http11Protocol start
Oct 29, 2013 9:16:11 AM org.apache.jk.common.ChannelSocket init
Oct 29, 2013 9:16:11 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/21 config=null
Oct 29, 2013 9:16:11 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 37783 ms
Oct 29, 2013 9:17:10 AM com.sun.faces.lifecycle.ELResolverInitPhaseListener populateFacesELResolverForJsp
Oct 29, 2013 9:17:50 AM com.sun.faces.lifecycle.RenderResponsePhase execute
sourceId=null[severity=(INFO 0), summary=(Welcome, Francisco), detail=(Welcome, Francisco)]
Oct 29, 2013 9:31:19 AM org.apache.catalina.core.AprLifecycleListener init
Oct 29, 2013 9:31:19 AM org.apache.coyote.http11.Http11Protocol init
Oct 29, 2013 9:31:19 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 880 ms
Oct 29, 2013 9:31:19 AM org.apache.catalina.core.StandardService start
Oct 29, 2013 9:31:19 AM org.apache.catalina.core.StandardEngine start
Oct 29, 2013 9:31:19 AM org.apache.catalina.startup.HostConfig deployDescriptor
Oct 29, 2013 9:31:20 AM org.apache.catalina.startup.HostConfig deployDescriptor
Oct 29, 2013 9:31:20 AM org.apache.catalina.startup.HostConfig deployWAR
Oct 29, 2013 9:31:21 AM org.apache.catalina.core.StandardContext addApplicationListener
Oct 29, 2013 9:31:49 AM com.sun.faces.config.ConfigureListener contextInitialized
Oct 29, 2013 9:31:52 AM org.apache.catalina.startup.HostConfig deployDirectory
Oct 29, 2013 9:31:52 AM org.apache.coyote.http11.Http11Protocol start
Oct 29, 2013 9:31:52 AM org.apache.jk.common.ChannelSocket init
Oct 29, 2013 9:31:52 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/54 config=null
Oct 29, 2013 9:31:52 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 32880 ms
Oct 29, 2013 9:37:45 AM com.sun.faces.lifecycle.ELResolverInitPhaseListener populateFacesELResolverForJsp
Oct 29, 2013 9:37:47 AM com.sun.faces.lifecycle.RenderResponsePhase execute
Hi Jerome,
since the logs look indeed ok to me - could you please double check your memory settings for the JVM?
The following minimum settings should be found in bin/catalina.sh:
Can you please also have a look on the Configure / System Information page to make sure that you are really using the Oracle VM?
If all fails, please send the output of http://localhost:18080/klaros-web/monitoring?format=pdf to support@verit.de so we may have a closer look. The credentials asked for are the ones you have entered at installation time for the tomcat administrator.
P.S.: Thanks for the detailed installation instructions - we took the hint ... ;)
-XX:MaxPermSize=192m -Xms256m -Xmx512m |
Youngling Posts: 4 Join Date: 10/29/13 Recent PostsTorsten Stolpmann:
Hi Jerome,
From what I can see in bin/catalina.sh:
root@klaros:/opt/klaros/bin# cat catalina.sh | grep XX
-XX:MaxPermSize=192m -Xms256m -Xmx512m org.apache.catalina.startup.Bootstrap "$@" start
-XX:MaxPermSize=192m -Xms256m -Xmx512m org.apache.catalina.startup.Bootstrap "$@" start \
Do I need to edit anything manually, this was obviously created during setup?
I've attached a screenshot of the system information page and i've also tried to include the PDF but it failed login and gave me the below:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.lang.IllegalArgumentException: No enum constant net.bull.javamelody.TransportFormat.PD
java.lang.Enum.valueOf(Enum.java:236)
net.bull.javamelody.TransportFormat.valueOf(TransportFormat.java:45)
net.bull.javamelody.TransportFormat.valueOfIgnoreCase(TransportFormat.java:147)
net.bull.javamelody.SerializableController.doSerializable(SerializableController.java:79)
net.bull.javamelody.MonitoringController.doCompressedSerializable(MonitoringController.java:295)
net.bull.javamelody.MonitoringController.doCompressedSerializable(MonitoringController.java:275)
net.bull.javamelody.MonitoringController.doReportCore(MonitoringController.java:200)
net.bull.javamelody.MonitoringController.doReport(MonitoringController.java:183)
net.bull.javamelody.MonitoringController.doActionIfNeededAndReport(MonitoringController.java:141)
net.bull.javamelody.MonitoringFilter.doMonitoring(MonitoringFilter.java:340)
net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:170)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.32 logs.
I'll monitor for a bit and see if it keep falling over or not, perhaps a once off? Let me know if you see anything.
Jerome
Hmm since the PDF generating obviously failed - can you reach the interactive page at http://localhost:18080/klaros-web/monitoring ?
HTH,
HTH,
RE: Klaros 3.8.3 - Tomcat / Klaros shut down randomly (Answer)
HTH,
HTH,
I think that was my mistake. I didn't auth with the correct details.
I've since changed that and emailed you as requested.
Jerome
