Test Maintenance - Test cases duplication with irrelevant headlines/details - Klaros Test Management - Forum - Klaros Test Management
Laxmi Shantharam Hegde, modified 11 Years ago.
Youngling Post: 1 Join Date: 3/25/13 Recent Posts
Hi ,
Found this issue in Klaros , found that the "Test cases when duplicated ,are getting saved with irrelevant headlines/details".
Step 1 - Create a new test case test1( all details filled), saved
Step 2 - Duplicate the test1 (name - test2 , fill the details) saved
Step 3 - go to test maintenance screen, The second( duplicated test - test2 is saved with some irrelevant names of some other test case and also test headline and the contents within the test case does not match.
Note -
2 Users are simultaneously creating test cases.Test name and test case details created by one user are jumbled with ones created by other user.
When on klaros version 3.6.4 , did not come across such an issue.
Current Klaros Information-
Klaros version - 3.7.7
Mysql version - 5.5.27
It will be of great help if someone one could point out if it is an issue with the installation of the tool or issue with Klaros.
Laxmi
Note -
Laxmi
