RE: project re-import - mixed up content - Klaros Test Management - Forum - Klaros Test Management
Roy Schumacher, modified 12 Years ago.
we found an issue after re-importing projects.
the import was done for all project (3) in one xml-file.
everything went fine but the names of the testcases were all mixed up so we had to re-edit each of them ;(
is this a knowsn issue?
how can we be sure to have an smooth re-import?
shall we export each project seperate?
thanks.
thanks.
Hello Roy,
Can you please add some detail on your setup? See my other post for needed information here.
Hello Roy,
We were trying hard to reproduce this issue but had no success.
Can you please describe in detail what fields were affected?
Can you please add some more detail on what you were experiencing here?
Is it possible to get our hands on the export files?
all the headlines are mixed up.
headlines and steps are not matching anmore.
maybe it has to do with the reimport?
example:
testcase 1: headline = this is the first test
testcase 2: headline = this is the second test
both headlines are swapped and so the content of the testcase does not make sense anymore,
i will try to deliver more details.
we are using the latest klaros version with sql db (utf-8) and tomcat on linux.
roy
example:
roy
