Klaros-Testmanagement 5.0.0 released - Klaros Test Management - Forum - Klaros Test Management
We are happy to announce the availability of Klaros-Testmanagement 5.0.0.
Whats new?
Usability
Reporting
Performance:
Installation
Databases
In total more than 13 bugs have been fixed, and 50 improvements as well as 15 new features have been added.
New Features
Improvements
Fixes
Whats new?
Usability
- Descriptions for test cases, test steps, etc. are now editable as rich text and may contain images
- Table contents can be edited directly in the individual cells via mouse click
- Frequently used functions can be triggered by keyboard shortcuts
- List entries can be reordered by drag-and-drop
- Table sorting by clicking on the corresponding column header
- Bookmarks can be copied directly to the clipboard
Reporting
- Dashboard contents can now be individually configured and saved. Individual dashboards can be defined as project presets and shared with other users
- The predefined reports have been completely revised and new reports have been added
- The diagram display has been significantly accelerated by asynchronous loading
- Dashboard diagrams can be exported as image files for further processing
- Data tables can now also be exported in XML and PDF formats
- Print pages optionally contain additional diagrams
Performance:
- Database layout has been optimized and database access has been completely reworked
- Batch transactions, especially for write operations, are now processed substantially faster
Installation
- The Java runtime environment is now integrated and automatically installed.
- Klaros uses the current LTS (Long Term Support) Java Runtime Environment Version 11
- The Tomcat application server has been updated to the current version 9
Databases
- The MySQL database is now also supported in version 8.
Release Notes
Version 5.0.0 (14.09.2020)New Features
Improvements
Fixes
