klaros as a service ubuntu - Klaros Test Management - Forum - Klaros Test Management
Aditya Vijjan, modified 6 Years ago.
Youngling Posts: 2 Join Date: 7/16/19 Recent Posts
I have created Klaros.service file in /etc/systemd/system and below id the file config. I am able to start stop klaros service.
[Unit]
Description=Klaros
After=network.target
[Service]
Type=forking
When i am trying to enable klaros service by systemctl enable klaros i received below details.
sudo systemctl enable klaros
The unit files have no installation config (WantedBy, RequiredBy, Also, Alias
settings in the [Install] section, and DefaultInstance for template units).
This means they are not meant to be enabled using systemctl.
Possible reasons for having this kind of units are:
1) A unit may be statically enabled by being symlinked from another unit's
.wants/ or .requires/ directory.
2) A unit's purpose may be to act as a helper for some other unit which has
a requirement dependency on it.
3) A unit may be started when needed via activation (socket, path, timer,
D-Bus, udev, scripted systemctl call, ...).
4) In case of template units, the unit is meant to be enabled with some
instance name specified.
[Unit]
Description=Klaros
[Service]
Type=forking
RE: klaros as a service ubuntu (Answer)
Haven't verified this yet, I think you are missing something like this:
I will check back later once verified.
[Install] | |
WantedBy=multi-user.target |
Hello Aditya,
the following is a verified solution for systemd (/etc/systemd/system/klaros.service):
Please note that the User=klaros setting requires the creation of a user and setting the correct ownership for /opt/klaros-testmanagement:
There is no need to run Klaros under a root account and we discourage users to do so.
[Unit] | |
Description=Klaros Testmanagement Service | |
After=syslog.target network.target | |
[Service] | |
Type=forking | |
User=klaros | |
ExecStart=/opt/klaros-testmanagement/bin/startup.sh | |
ExecStop=/opt/klaros-testmanagement/bin/shutdown.sh | |
[Install] | |
adduser klaros | |
chown -R klaros /opt/klaros-testmanagement |
