Support for UTF-8 (Arabic character set) - Klaros Test Management - Forum - Klaros Test Management
Musa Haidari, modified 6 Years ago.
Dear team,
Thank you in advance.
RE: Support for UTF-8 (Arabic character set) (Answer)
Dear Musa,
Dear Torsten,
@@character_set_database
@@collation_database
Musa Haidari
Musa Haidari
Dear Musa,
