Klaros-Testmanagement 4.9.7 released - Klaros Test Management - Forum - Klaros Test Management
We are pleased to announce the release of Klaros-Testmanagement version 4.9.7.
This is a maintentance release fixing a regression in 4.9.6 where the issue details page was not accessible for non-Jira issue trackers and adding several performance related improvements.
Overall 5 improvements and 4 stability fixes have been implemented in this release. Existing users are encouraged to upgrade.
What is new in Klaros-Testmanagement Version 4.9?
Release Notes
Version 4.9.7 (26.11.2018)
Improvements
[KLAROS-4035] - Add access to the system under test issue list in the community edition
[KLAROS-4034] - Avoid caching of pages reached by browser back button
[KLAROS-4033] - Improve overall page load speed
[KLAROS-4026] - List all revisions of a test case when creating an issue
[KLAROS-4025] - Improve performance when bulk editing sub-jobs
Bug Fixes
[KLAROS-4036] - The newest test case result toggle option in the test case list is not responding
[KLAROS-4027] - Unable to navigate to the details page of an non-Jira issue
[KLAROS-4024] - Test suite attachments not visible on the details page
[KLAROS-3729] - When "Reopen and Execute" a job, its progress rate is not automatically set to 0
Version 4.9.6 (13.11.2018)
Improvements
[KLAROS-3369] - Support the Jira custom field "Sprint"
[KLAROS-3991] - Display the number of test cases per segment on the test segment list page
[KLAROS-4001] - Add support for collapsing and expanding complete test segments referenced in a test case step list
[KLAROS-4006] - Allow to search for issues using the global search
[KLAROS-4009] - Allow to create issues as a sub task in Jira
[KLAROS-4010] - Support the Jira custom field "GroupPicker"
[KLAROS-4011] - Add support for bulk printing and deleting unfinished test runs on the continue test run page
[KLAROS-4013] - Do not require users to log in for accessing attachments of detail pages that are explicitly opened for anonymous access
[KLAROS-4014] - Introduce an option to hide other users from Tester or Guest roles in the user management if desired
[KLAROS-4018] - Full text search results should be sorted by their alphabetical order in locales other than English
[KLAROS-4020] - Allow to show the full text search results on browse pages
[KLAROS-4021] - Support quick filtering on a per table basis using associative full text search for keywords
[KLAROS-4022] - Improve loading speed of job lists where jobs are containing sub jobs
Bug Fixes
[KLAROS-4005] - Fix the import of embedded test result attachments
Version 4.9.5 (17.09.2018)
Improvements
[KLAROS-3937] - When resolving references in attachments, honor the attachment version number when retrieving the data
[KLAROS-3953] - It should be displayed on the issues by test cases table how many issues have been resolved per test case and how many are still open
[KLAROS-3958] - Support LSB 3.1 comment conventions for init scripts in the Klaros service script
[KLAROS-3963] - When linking issues to an individual sut the sut to assign to should not be selectable
[KLAROS-3965] - List the results of all revisions on the test case result page
[KLAROS-3968] - If a test result import is triggered by a job, a comparison of the delivered results and the tests defined in the job should take place and unexpected results should then be preset to 'Ignore'
[KLAROS-3969] - Allow to individually select the test results to import from an automated test execution
[KLAROS-3970] - List test case result details on the test run print page when verbose setting is selected
[KLAROS-3972] - Suppress puzzling HHH020008 'A soft-locked cache entry was expired by the underlying Ehcache' warning messages in the log file
[KLAROS-3978] - Allow to select all existing revisions of a test case or test suite when creating jobs on the job detail page
[KLAROS-3979] - Provide the ability to directly detach a linked requirement management system from a project in case it has been globally deactivated
[KLAROS-3981] - Fix the layout for excessively large test case description fields in the start test dialog and execute test window
Bug Fixes
[KLAROS-3470] - During manual import of test case results, it is possible to assign two different external test suites names to the same test suite in Klaros
[KLAROS-3929] - Test steps are moved/copied to the wrong position if the user presses the "move"/"copy" button too fast after selecting a target position
[KLAROS-3930] - Deleting a project should leave no leftovers in the database
[KLAROS-3931] - Misleading log message level for "ERROR, de.verit.klaros.web.service.search.FullTextSearchService Indexing class xxxx"
[KLAROS-3932] - In some situations attachments on the test case result page are not displayed when navigating to this page
[KLAROS-3936] - The 'Save' and 'Discard' buttons are enabled if an attachment is updated in a newer revision and then the user switches back to the original revision
[KLAROS-3952] - Not possible to assign more users to a project if users are already assigned to the project
[KLAROS-3954] - The user print page should display the open jobs of the selected user instead of the logged in user
[KLAROS-3956] - NPE when trying to link an issue to a test case without selecting a sut
[KLAROS-3960] - Unable to purge project due to job timeblock constraints
[KLAROS-3961] - When importing a project backup which contains references to a disabled exisiting issue management system the imported issues should be assigned to the existing system
[KLAROS-3962] - Error removing password for issue management background sync operation
[KLAROS-3966] - Unable to parse Excel sheets with additional content placed outside the last labeled column for dynamic value replacement
[KLAROS-3971] - Newly created test suites during test case result import should automatically contain the references test cases
[KLAROS-3982] - Exception when trying to delete a category node
Version 4.9.4 (16.08.2018)
Improvements
[KLAROS-3912] - Add a column "test case" to the linked issues table on the SUT details page
[KLAROS-3915] - Improve create and link actions for issues that are only assigned to a system under test but not to a specific test case
[KLAROS-3920] - Add support for moving individual test steps or test segment instances of a test case up or down with a single click
[KLAROS-3922] - Reference prefixes (e.g. env-att, tc, inline-att) should be case insensitive
[KLAROS-3923] - When deleting test segments, all previous revisions of a test segment should be removed from the test cases where they are referenced
[KLAROS-3924] - When duplicating a test case step or test segment, preselect the follow-up position as the target position for the duplicate
[KLAROS-3925] - Clearer wording for the text in dialog windows when moving or cloning elements of a list
Bug Fixes
[KLAROS-3756] - Do not change the order of unsaved objects after switching sections
[KLAROS-3760] - The back navigation on the Evaluate / Issues / Link Issue page does not always redirect correctly
[KLAROS-3910] - Newly created or linked issues without an assigned test case are not immediately displayed on the system under test details page
[KLAROS-3913] - The projects to be imported are not displayed after uploading the XML backup file
[KLAROS-3914] - Deleted test runs are not filtered from the print pages
[KLAROS-3916] - Test suite can not immediately be deleted after deleting all test runs
[KLAROS-3919] - Unable to cancel bulk clone operation for test cases
[KLAROS-3921] - The "Latest Issues" table on the sut details page is not refreshed properly
[KLAROS-3926] - Page visit information will not be cleaned after clicking the "Back" button on the link issue page
Version 4.9.3 (30.07.2018)
Improvements
[KLAROS-2004] - Increase the Import test result performance for projects with a large number of test results
[KLAROS-3643] - If an iteration is selected, creating a new revision of a requirement should optionally add that requirement to the iteration
[KLAROS-3757] - Improve save and navigation behavior on the test case / test suite details page when executing review jobs
[KLAROS-3818] - Add "is set" and "is not set" to the list of filter options for selection fields
[KLAROS-3867] - Sort the dropdown list of test segments alphabetically
[KLAROS-3869] - Adding job dependencies should only be allowed if additional jobs are available
[KLAROS-3875] - Document the resolved states mappings for issues
[KLAROS-3881] - Allow to edit job work log entries of test execution jobs
[KLAROS-3882] - Speed up calender popup rendering
[KLAROS-3887] - Improve overall performance of test run creation when starting manual tests and deletion from the test run list
[KLAROS-3888] - Improve performance of custom attribute creation and deletion
[KLAROS-3891] - Enhance reproducability of XML backup file creation by always ordering user defined property values in the same order
[KLAROS-3893] - Allow access to the project print page from the project list
[KLAROS-3895] - Support direct navigation to the selected project and iteration details pages from the top bar entries
[KLAROS-3899] - The events on the notification scheme details page should be sorted alphabetically
[KLAROS-3904] - Full text search support for modified test segments in test cases
[KLAROS-3906] - Empty SUT / ENV names should be substituted with their ids in the test run report
Bug Fixes
[KLAROS-3739] - Misbehaviour when working with jobs of type task
[KLAROS-3835] - The number of results shown on the execute test suite page is not refreshed after executing a test suite through a job
[KLAROS-3857] - Editing custom fields of a test case is disabled when the test case state is set to skip execution
[KLAROS-3858] - Unnecessary HTML escape squence in print page title sections for umlauts
[KLAROS-3859] - User defined properties with a '%' in their name are skipped while resolving references
[KLAROS-3860] - Exception when a user defined property with a '$' or '\' in its name is encountered during test execution
[KLAROS-3861] - Job dependencies of sub jobs are not deleted when deleting the parent job
[KLAROS-3862] - When editing a test case, then creating or linking an issue and finally saving the test case, the issue is no longer linked to the test case
[KLAROS-3863] - When moving or cloning steps of a test case, the possible target positions do not have correct position numbers if test segments are used
[KLAROS-3864] - The Job detail report should not include unscheduled jobs if a start/end date has been set
[KLAROS-3865] - Exception when cloning a test segment in a test case and saving
[KLAROS-3868] - Unable to copy a single item with an empty name field when using Oracle as a database
[KLAROS-3870] - Job time block and work log items are not directly associated with their corresponding project configuration upon creation
[KLAROS-3872] - Test run properties (set before starting a test run) are not transferred into the test runner
[KLAROS-3876] - Progressbar is missing when executing a job of type task
[KLAROS-3879] - Purging a project fails if external requirements and/or external test cases are present that are linked to that project
[KLAROS-3880] - Updating an issue from the issue details page removes it from the linked test case
[KLAROS-3892] - The number of test runs on the project list page should not include pending test runs
[KLAROS-3897] - Launching a single test case from the test suite execution dialog fails without visual feedback
[KLAROS-3898] - Exception after removing a target from a notification scheme and then updating this notification scheme
[KLAROS-3900] - No e-mail notification sent when a job is created via "jobs from test cases" or "jobs from test suites"
[KLAROS-3901] - The iteration PDF overview report must not cover deleted test runs
[KLAROS-3908] - When importing test case results for the first time the generated test suite does not contain the generated test cases
Version 4.9.2 (29.06.2018)
Improvements
[KLAROS-3855] - Add support for the PostgreSQL9Dialect
[KLAROS-3853] - Enhance reproducability of XML backup file creation by always ordering properties in the same order
[KLAROS-3837] - Remove the inactive, duplicate Save/Discard buttons from the bottom of the notification settings detail page
[KLAROS-3838] - Allow to break long database information strings on the overview page
[KLAROS-3844] - Use a postfix notation when creating new names cloned objects and add counts if needed
Bug Fixes
[KLAROS-3854] - Error during generating test execution jobs for a dedicated parent job
[KLAROS-3850] - Exception after saving a large string entry for the job description field
[KLAROS-3852] - Backup XML import may fail if external requirements management systems are linked to a project in the backup file
[KLAROS-3848] - Reimported project backups may contain empty test step shadow information
[KLAROS-3849] - Importing backups from non-Derby databases breaks if the derby string limit for large strings is exceeded
[KLAROS-3839] - Test cases serialized over the resource api must not try to expose step container information
[KLAROS-3847] - The test run report report sample accesses the test step fields action, precondition and postcondition in a deprecated way
[KLAROS-3840] - XML Backup should strip illegal XML characters from database content
[KLAROS-3842] - When an admin purges a project from the database, users currently using this project will not be removed from the project gracefully
Version 4.9.1 (08.06.2018)
Bug Fixes
[KLAROS-3831] - Exception after skipping all test steps of a test case execution for which no steps have yet been executed
[KLAROS-3833] - Exception on the test case list page while using an Oracle database
[KLAROS-3834] - User defined JIRA fields are sporadically not transferred when synchronizing requirements
Version 4.9.0 (01.06.2018)
New Features
[KLAROS-3714] - Support CAS Authentication
[KLAROS-3800] - Support changing individual steps of an included test segment on a per test case basis
Improvements
[KLAROS-2288] - Optionally show jobs on the user print pages
[KLAROS-2567] - Add information from the details pages' overview tabs to the print pages
[KLAROS-3464] - When creating copies of sub jobs they should be created within their parent job
[KLAROS-3688] - Allow to download backups of single projects through a RESTful web service
[KLAROS-3691] - Mark changed test case results on the test case result list
[KLAROS-3705] - On the test segment details page, show the number of test cases this segment is included in on the "test cases" tab
[KLAROS-3759] - Disable the "New" and "Link" buttons on the evaluate issues page if no IMS is assigned to the current project
[KLAROS-3763] - Show a hint on the test case and system under test details page under the issue tab if no issue management system has yet been added to the project
[KLAROS-3768] - Properly sort the requirement and test suite references of a test case shown in the revision tab
[KLAROS-3776] - Increase the size of the text boxes for test step properties (action, precondition etc.)
[KLAROS-3782] - Add a 'print single result' option to the test suite result list page
[KLAROS-3783] - The 'continue test run' test case list doesn't show the already acquired results
[KLAROS-3787] - Improve the performance of the mandatory test step migrator during database migration
[KLAROS-3792] - Show the execution mode of a test case when listing test cases for execution
[KLAROS-3798] - Show an icon on the details page that indicates if a test case or test suite is synchronized
[KLAROS-3802] - Lists of attachments should be sorted by name instead of creation date
[KLAROS-3803] - Limit the number of unnecessary history entries for test cases, if test segments are included
[KLAROS-3823] - Skipping remaining test steps takes too long for large numbers of steps
[KLAROS-3830] - Jobs from disabled projects should be omitted from the list of executable jobs when foreign projects are displayed
Bug Fixes
[KLAROS-3573] - Skip synchronized test cases when bulk editing or bulk create new revisions
[KLAROS-3721] - When cloning a test case with attachments the newly created test case is marked as modified when first opening its test case details page
[KLAROS-3735] - Copying objects into another project should ignore the order of user defined property enum values when deciding if a property definition is already defined in the target project
[KLAROS-3755] - Changes must be confirmed twice on the iteration details page when changing properties and assignments in different tabs
[KLAROS-3758] - The 'New issue' button on the system under test details page does not redirect to to the issue creation page
[KLAROS-3761] - Remove superfluous ui elements of deactivated enterprise edition features from the community edition
[KLAROS-3764] - Unable to delete issue management systems
[KLAROS-3766] - The due date is shown instead of the start date in the job info panel for parent jobs
[KLAROS-3767] - The parent job is not properly updated when removing sub jobs
[KLAROS-3769] - Exception when deleting parent jobs that have circular dependencies on their child jobs
[KLAROS-3770] - Exception when moving sub-jobs to another position
[KLAROS-3771] - After moving sub-jobs between levels a "Concurrent modification conflict" pop-up will show up
[KLAROS-3772] - Newly created jobs after a project change are not immediately visible when a parent job is selected during the project change
[KLAROS-3773] - If an externally synchronized requirement enumeration field is emptied, fields in Klaros that were linked to that field still show its former value
[KLAROS-3774] - When deleting the last sub job on a parent job's page, the user should be navigated back to the job list page
[KLAROS-3775] - Exception when adding and saving a new sub job if the sub job page of a parent job is open
[KLAROS-3778] - Impossible to handle merge conflicts of boolean fields
[KLAROS-3779] - Unsaved jobs can be moved to another position
[KLAROS-3780] - Unable to retrieve user defined properties on the configuration print page
[KLAROS-3781] - Some Print pages containing test results or test runs can not be accessed
[KLAROS-3785] - The header column for skipped test results in the 'test environment' and 'system under test' reports is to small under Linux with a German locale
[KLAROS-3788] - Changing test step information on a test segment does not properly trigger last changed information on the test cases including this test segment
[KLAROS-3794] - Changes to content of synchronized test suites are not triggering synchronization markers when these test suites are initialized from projection instances
[KLAROS-3795] - A newly created project is not immediately visible to the user in the global role manager who created it
[KLAROS-3796] - The number of test suite executions shown on the test suite execution page is reset after executing the test suite from within this page
[KLAROS-3801] - When adding inline attachments of a test segment to a field in a test case that has included the same test segment more than once, the attachment is shown multiple times in the list of includable attachments
[KLAROS-3805] - Line breaks on a print page of a test suite are not displayed correctly
[KLAROS-3807] - The list of sub jobs should not offer sort options
[KLAROS-3808] - The test case print page is missing steps from test segments
[KLAROS-3810] - When trying to save via the dialog that opens after creating a new sub job and then opening the filter panel, not all objects are properly saved
[KLAROS-3813] - Exception when adding and then deleting an attachment during test execution
[KLAROS-3814] - Pressing the 'delete attachment' button at the end of a test execution has no effect
[KLAROS-3822] - Users are listed twice when creating review jobs via test case details page or test suite details page
[KLAROS-3824] - Exception when importing test runs for unknown test cases
[KLAROS-3825] - IndexOutOfBoundsException when changing the a project to execute a job if the target project has no system under test or test environment
[KLAROS-3826] - HibernateExeception when navigating to "Continue Test Run" in the role "Tester" with activated option "Testers may only resume jobs assigned to them"
[KLAROS-3827] - If an Excel attachment contains empty rows, none of the cells can be referenced
[KLAROS-3829] - Do not allow to assign reviews to users of role tester
- The reusable test segments, that had been introduced in Klaros-Testmanagement 4.8, can now be used in a new way when they are included in test cases. By pressing the edit button on included steps, they can now be edited like any other test case step.
- Klaros-Testmanagement Enterprise Edition now supports single sign-on via CAS (Central Authentication Service).
- In addition to our RESTful Remote API, we've implemented another RESTful service, which allows to create backup files of single projects via remote requests.
- The print pages have been considerably expanded, including additional information previously only displayed on the overview tabs.
Release Notes
Improvements
Bug Fixes
Improvements
Bug Fixes
Improvements
Bug Fixes
Improvements
Bug Fixes
Improvements
Bug Fixes
Improvements
Bug Fixes
Bug Fixes
New Features
Improvements
Bug Fixes
