Klaros-Testmanagement 5.3.1 released - Klaros Test Management - Forum - Klaros-Testmanagement
We are happy to announce the availability of Klaros-Testmanagement 5.3.1. This is a maintenance release that includes a total of 25 improvements and bug fixes.
Improvements include:
Iteration Tab
Both the Test Environment and System under Test details pages now have an 'Iterations' tab.
From within this tab, you can assign iterations and also detach previously assigned iterations.
Overhauled Report Tutorial
The custom report creation in our tutorial has been updated to include the newest version of Eclipse and Java. In addition, the example report that is used throughout that chapter has been reworked.
Be sure to check it out: https://www.klaros-testmanagement.com/files/tutorial/html/Tutorial.index.html
Release Notes Version 5.3.1 (10.12.2021)
Improvements
KLAROS-4952 - Improve the layout of the time control on the test activity and test progress history configuration dialog
KLAROS-4950 - Extend and refactor the result model class hierarchy for custom reports
KLAROS-4949 - Improve the report example in the report creation tutorial
KLAROS-4918 - Deleting a system under test should remove it from all test suites
KLAROS-4902 - Provide an iteration tab on the test environment and system under test details page
KLAROS-4813 - Deleted objects should be skipped during bulk operations
Fixed Bugs
KLAROS-4955 - The values shown on the detail pages do not match the data shown in the diagrams
KLAROS-4951 - Test activity dashboard report shows misleading labels for a project with single system under test and test environment
KLAROS-4947 - Wrong color assignments for skipped and inconclusive results in the test run history report
KLAROS-4946 - The Test Run History Report does not display the data for the selected period
KLAROS-4944 - Charts are not rendered on print pages
KLAROS-4935 - Unable to import XML backup when referenced issue management or requirements systems where edited by a user not yet present in the local database
KLAROS-4932 - External requirements with attachments are not properly synchronized
KLAROS-4925 - Test step result attachments cannot be deleted
KLAROS-4924 - Impossible to change user defined fields on non-persisted test step containers
KLAROS-4922 - Exception when changing the role of the user if another deleted user with the same name exists
KLAROS-4919 - Impossible to create new revisions of approved requirements
KLAROS-4917 - Stale reference from job to iteration persists after purging the iteration
KLAROS-4916 - Exception when bulk adding test cases to an existing test suite from the test case list page
KLAROS-4914 - Stale reference from test segment to test case persists after purging the test case
KLAROS-4913 - Impossible to bulk update user defined fields of test segments
KLAROS-4912 - User defined fields of test segments not visible on test case details page
KLAROS-4806 - If a requirement is assigned to an iteration via the requirement details page, this is only visible on the iteration details page after flushing the memory via Configure / Overview
KLAROS-4392 - External requirement fields that are linked to user defined fields are not updated
KLAROS-4375 - Invalid datetime values entered into date / time fields lead to exceptions
Iteration Tab
Improvements
Fixed Bugs
