RE: Test step is wrong when execute some test case - Klaros Test Management - Forum - Klaros-Testmanagement
Eileen Cao, geändert vor 9 Jahren.
Youngling Beiträge: 6 Beitrittsdatum: 19.05.16 Neueste Beiträge
Klaros 4.5.0
Preparation: Test cases are imported by Excel.
1) TC00013 and TC00014 are both in P00004 project.
2) When I execute the TC00013, the first step is wrong in the execution box. The action and expected result dispayed the step of TC00014’s.
I checked the data in the database, the data should be ok in table
K_TEST_CASE
K_REL_TC_FRAG
K_TC_STEP
I attached a word document to describe my issue. Please have a look and investigate, thanks.
Or any workaround?
K_TEST_CASE
K_REL_TC_FRAG
K_TC_STEP
Or any workaround?
Hi Eileen,
thanks for the detailed explanation, especially the provided database statements to verify that the testcases have been correctly imported. To narrow down the cause for this behaviour I need some more information about your configuration:
- Operating system version
- Browser version (do you have some kind of NoScript installed?)
Also, could you provide us with the Klaros-Testmanagement logs? You can find them at [user home]/.klaros/logs and [Klaros-Testmanagement-Installation]/logs
Kind Regards,
Kind Regards,
Appreciate your quick response.
Klaros is installed on linux OS.
root@wgq-65-100:/opt/klaros-testmanagement# uname -a
Linux wgq-65-100 4.2.0-27-generic #32~14.04.1-Ubuntu SMP Fri Jan 22 15:32:26 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Browser version is Chrome: 50.0.2661.102 m
log file and one of my spreadsheet is attached.
In the spreadsheet, the sheet14 means TC00013, sheet 15 means TC00014
By the way, could you give a email address? or I can send the database dump to you by mail if needed?
Because I imported 1000+ cases with 3000+ steps today.
Hi Eileen,
thanks for sending the logfile and the Excel-sheet!
You can send the database dump to support@verit.de so that we can take a look into it.
Hi, Fabian
I checked the sql command today. And I think that the SEARCH_HASH is not correct when executing the case.
We guess that the klaros supporting the chinese characters is not very good.
If I create a new test case with the same steps and expect results as the TC00013's, same wrong behavior when I executing the new case.
Current workaround is fill the "Precondition" and "PostCondition" information for each steps.
BR
Eileen
BR
Eileen
Hi Eileen,
sorry for the late reply, we have been busy with release preparations for the last few days.
You're right, we had some issues in calculating a proper hash if the fields of a step had only chinese characters, which we have now fixed as KLAROS-2969 (During execution, the runner erroneously displays the test case step fields of unrelated test case steps).
We have released a new version 4.5.1 yesterday that contains this fix which you can download right here:
http://www.klaros-testmanagement.com/en/download
Thanks again for your problem report, especially your SQL dump file which has been extremely helpful for testing purposes!
RE: Test step is wrong when execute some test case (Antwort)
Hi,Fabian
We upgraded the Klaros to 4.5.1.
This issue is fixed.
Thanks again!
BR
Eileen
Thanks again!
BR
Eileen
