We are pleased to announce the release of
Klaros-Testmanagement 5.0.1!
This is a maintenance release that introduces automated updating of parent job and subjobs when reopening a job. It also fixes an issue when migrating from Klaros 4.x using the preconfigured derby database.
What's new in Klaros-Testmanagement 5.0?With the switch to PrimeFaces as the underlying front end technology, the user interface underwent a complete revamp.
Usability- Descriptions for test cases, test steps, etc. are now editable as rich text and may contain images
- Table contents can be edited directly in the individual cells via mouse click
- Frequently used functions can be triggered by keyboard shortcuts
- List entries can be reordered by drag-and-drop
- Table sorting by clicking on the corresponding column header
- Bookmarks can be copied directly to the clipboard
Reporting- Dashboard contents can now be individually configured and saved. Individual dashboards can be defined as project presets and shared with other users
- The predefined reports have been completely revised and new reports have been added
- The diagram display has been significantly accelerated by asynchronous loading
- Dashboard diagrams can be exported as image files for further processing
- Data tables can now also be exported in XML and PDF formats
- Print pages optionally contain additional diagrams
Performance:- Database layout has been optimized and database access has been completely reworked
- Batch transactions, especially for write operations, are now processed substantially faster
Installation- The Java runtime environment is now integrated and automatically installed.
- Klaros uses the current LTS (Long Term Support) Java Runtime Environment Version 11
- The Tomcat application server has been updated to the current version 9
Databases- The MySQL database is now also supported in version 8.
In total more than 17 bugs have been fixed, and 51 improvements as well as 15 new features have been added.
Release Notes
Version 5.0.1 (18.09.2020)Improvements[KLAROS-4381] - Reopening a job should propagate updated status, success rate and progress information to its parent job
Fixes[KLAROS-4465] - Migration from Klaros 4.x is not being completed if the preconfigured derby database is used
[KLAROS-4460] - Opening the Edit Categories panel fails if the table has unsaved changes
[KLAROS-4459] - Notification Schemes cannot be deleted
[KLAROS-4386] - Reopening a job via bulk edit doesn't automatically reopen its sub jobs
Version 5.0.0 (14.09.2020)New Features[KLAROS-479] - Allow sorting tables by clicking on the table header
ImprovementsKLAROS-214] - Long running operations should give a visual progress feedback
Fixes[KLAROS-3730] - When a details page is opened twice in the same browse session in the presence of unsaved changes, a dialog may be displayed indicating unsaved changes
