Redmine Authentication Failed
Bev Dellosa, geändert vor 7 Jahren.
Youngling Beiträge: 7 Beitrittsdatum: 21.12.18 Neueste Beiträge
Redmine version: 3.4.1 stable
Klaros version: 4.9.7
Mylyn version: 2.8.2 stable
Thank You,
Bev
Hi Bev,
2018-12-20 00:42:39: ERROR, de.verit.klaros.web.handler.GlobalExternalConnectionHandler, http-nio-18080-exec-1 Unable to connect to external server IM00001 at http://192.168.168.222/login
de.verit.klaros.exception.KlarosServiceException: net.sf.redmine_mylyn.core.RedmineStatusException: net.sf.redmine_mylyn.api.exception.RedmineApiHttpStatusException: Unexpected status code - 404 Not Found
Bev
Hi Bev,
Thank You,
Bev
Hi Bev,
There is no proxy server involved here. I also tried adding a trailing  slash but still got the same issue.
Bev
RE: Redmine Authentication Failed (Antwort)
Hi Bev,
Hi Fabian,
Bev
Hi Bev,
the screenshot you've provided shows the settings screen, but the project names are instead listed on the projects page (Administration/Projects):
Hi Fabian,
You're right, I was looking at the wrong screen. emoticon
I changed the Project ID and it is working now! emoticon Thanks so much to you and to Torsten for being patient with me.
Best Regards,
Bev
Hi Bev,
Be sure to check out this page if you run into any other issues, though!
