RE: no longer execute at once all the test cases - Klaros Test Management - Forum - Klaros-Testmanagement
Markus Nagel, geändert vor 13 Jahren.
Youngling Beiträge: 5 Beitrittsdatum: 26.06.12 Neueste Beiträge
Hi
I can no longer execute at once all the test cases. There are test cases with two steps. When selecting the Execute buttons nothing happens. I found the following entry in the log. Is this an approach to problem solving?
Best regards
Markus Nagel
2012-06-29 13:49:14: WARN, com.icesoft.faces.webapp.http.core.DisposeViews, http-18080-3 Request belonging to a different session. Most probably servlet filters mangled the request. | |
2012-06-29 13:50:12: WARN, org.jboss.seam.security.permission.PersistentPermissionResolver, main no permission store available - please install a PermissionStore with the name 'org.jboss.seam.security.jpaPermissionStore' if persistent permissions are required. | |
2012-06-29 13:51:57: WARN, com.icesoft.faces.webapp.http.core.DisposeViews, http-18080-4 Request belonging to a different session. Most probably servlet filters mangled the request. | |
2012-06-29 13:53:00: ERROR, net.sf.ehcache.hibernate.strategy.AbstractReadWriteEhcacheAccessStrategy, http-18080-4 Cache de.verit.klaros.core.persistent.PersistentObject Key de.verit.klaros.core.persistent.PersistentObject#6416901b-54d1-42fc-b68e-23aa63db3d4d Lockable : net.sf.ehcache.hibernate.strategy.AbstractReadWriteEhcacheAccessStrategy$Item@1cd0d58 | |
A soft-locked cache entry was removed already. Out of balance lock/unlock sequences ? | |
2012-06-29 13:55:16: ERROR, net.sf.ehcache.hibernate.strategy.AbstractReadWriteEhcacheAccessStrategy, http-18080-7 Cache de.verit.klaros.core.persistent.PersistentObject Key de.verit.klaros.core.persistent.PersistentObject#52a64a21-4489-4fd6-b7e7-d58bea14693c Lockable : net.sf.ehcache.hibernate.strategy.AbstractReadWriteEhcacheAccessStrategy$Item@1742389 | |
2012-06-29 14:55:21: ERROR, net.sf.ehcache.hibernate.strategy.AbstractReadWriteEhcacheAccessStrategy, http-18080-5 Cache de.verit.klaros.core.persistent.PersistentObject Key de.verit.klaros.core.persistent.PersistentObject#528439e8-e1ac-4966-92f8-9fc674a87aba Lockable : net.sf.ehcache.hibernate.strategy.AbstractReadWriteEhcacheAccessStrategy$Item@1a9790c | |
2012-06-29 14:56:33: WARN, com.icesoft.faces.webapp.http.core.DisposeViews, http-18080-7 Request belonging to a different session. Most probably servlet filters mangled the request. | |
2012-06-29 15:04:13: ERROR, net.sf.ehcache.hibernate.strategy.AbstractReadWriteEhcacheAccessStrategy, http-18080-7 Cache de.verit.klaros.core.persistent.PersistentObject Key de.verit.klaros.core.persistent.PersistentObject#c684657b-82ff-4ce2-89e9-400e51248cf5 Lockable : net.sf.ehcache.hibernate.strategy.AbstractReadWriteEhcacheAccessStrategy$Item@18fabb5 | |
Best regards
Markus Nagel
The messages shown are harmless.
Some browsers tend to disable the popup browser window on first start which is used for executing test cases.
Can you please check if this is the case?
Hi Thorsten
The problem is solved. The solution was much easier. I had many windows open. Besides these, there was still an open Run window. So I could not execute further tests.
Tanks and best regards, Markus
