RE: Can't integrate with readmine
Mai Farid El Banouby, geändert vor 13 Jahren.
Youngling Beiträge: 4 Beitrittsdatum: 08.03.12 Neueste Beiträge
First, I am working with Klaros v3.5 and readmine 1.3.1.
The problem is that when I run test case and try to create ana issue, An authentication for readmine appears then I write my login data as I enter in the readmine but ERROR says "Authentication failed (wrong user name or password)."
In readmine's settings I changed the Authentication Required and the Enable REST Web Service checkbox to be checked
But The plugin I have a problem that's its not supported for my readmine's version so what can I do??
Another question do I need a LDAP authentication account in readmine or not??
Waiting for your reply.
Thanks a lot.
Best Regards,
Mai Farid
Hello Mai Farid,
What version of the redmine-mylyn-connector did you install in your Redmine installation (should be 2.7.6)?
Did you test your redmine setup in the Configuration / Issue Management section?
If possible, please send your relevant log files (<Installation dir>/logs) to support@verit.de so we may have a look at this.
You do not need an LDAP authentication account in Redmine.
I don't know how to install redmine-mylyn-connector and the URL"http://sourceforge.net/apps/wordpress/redmin-mylyncon/" in the document I can't find the plugin.
I tested it but its not working as it requests for username and password and it gives me the same issue.
I sent the logs files too.
Thanks so much.
Mai Farid
The redmine integration requires the installation of the WS-API plugin.
The installation instruction are located at the bottom of the page: http://sourceforge.net/apps/wordpress/redmin-mylyncon/:
Howto install
You can install the Eclipse Plugin via our Update-Site
http://redmin-mylyncon.sourceforge.net/update-site/N/
Update it with
Note: this step requires the ruby-git bindings
but is it version 2.7.6???
Dear Torsten,
I have followed your steps
I ran the command:
It gave me the following:
C:\Program Files\BitNami Redmine Stack\apps\redmine>ruby script/plugin install -
-force git://redmin-mylyncon.git.sourceforge.net/redmin-mylyncon/redmine-plugin
Invalid gemspec in [C:/Program Files/BitNami Redmine Stack/ruby/lib/ruby/gems/1.
8/specifications/capistrano-2.9.0.gemspec]: invalid date format in specification
: "2011-09-24 00:00:00.000000000Z"
8/specifications/gemcutter-0.7.1.gemspec]: invalid date format in specification:
"2011-12-02 00:00:00.000000000Z"
8/specifications/term-ansicolor-1.0.7.gemspec]: invalid date format in specifica
tion: "2011-10-13 00:00:00.000000000Z"
The only thing happened is it created and empty folder in the redmine/vendor/plugins
nothing else happened.
I searched over the internet but I couldn't find any useful information.
Please I am desperate and I need your help on this, I need from you step by step on how to install this Mylyn connector for Redmine version 1.3.1 and please take care of the version number 1.3.1
Thanks for your efforts and I will be looking forward for your early reply.
Regards!
RE: Can't integrate with readmine (Antwort)
I am not a Ruby user, but please have a look at:
https://github.com/capistrano/capistrano/issues/153
https://github.com/jadb/capcake/wiki/Invalid-Date-Format-in-Specification
https://github.com/capistrano/capistrano/issues/132
All of which came up first when searching for the error string '/specifications/capistrano-2.9.0.gemspec]: invalid date format in specification'.
Hope this will get you back on track,
