RE: Klaros-Testmanagement version 3.4.8 released
Tobias Schmitt, geändert vor 7 Jahren.
Klaros-Testmanagement version 3.4.10 released
We are pleased to announce the release of Klaros-Testmanagement version 3.4.10.
For users of the Enterprise Edition the new release introduces to following new features:
  • Objects like test cases and test suites can now be assigned to definable categories
  • Print views of test cases, test suites and test results can now be accessed directly from the results pages
The Community and Enterprise Edition both gain the following new features:
  • Test execution can now be carried out with a tabular view of test steps
  • Multiple selection is now available in table views. This allows quick operations on large amounts of data
  • Errors can now be assigned to individual test steps
  • HTTP and SOCKS proxies are now supported
  • Read-only access to the content repository via WebDAV/HTTP from outside Klaros
Release Notes:
Version 3.4.10 - 2012-03-02:
[KLAROS-1494] - New subjobs will not be created in the correct location under certain conditions
[KLAROS-1493] - Exception on save before some bulk actions if global select is set.
[KLAROS-1491] - Category assign button can be enabled if no category group is selected.
[KLAROS-1490] - Problem adding a prior unsaved job as a subjob
[KLAROS-1488] - Invalid Parameter Exception in Subjob handling
[KLAROS-1485] - Error while bulk creating test case revisions
[KLAROS-1484] - Missing test cases in test case categories
[KLAROS-1483] - Synchronisation error when cloning test cases
[KLAROS-1480] - Importing test results may fail when two test cases share the same name and no results have been imported for either one
[KLAROS-1476] - Method not found: dropChangesBeforeBulkNewRevision() when skipping save before bulk revision creation
[KLAROS-1382] - Broken Paging in the test run history report
[KLAROS-1492] - Numbers in Category view menus should show entities in the category and also the total number of entities in the category and its sub-categories.
[KLAROS-1487] - Add a confirmation dialog when an expired due date is entered for a newly create job
Version 3.4.9 - 2012-06-01:
[KLAROS-1470] - Wrong default port values for console mode installation
[KLAROS-1422] - Hibernate triggers unnecessary updates on test suites for every submit
Version 3.4.8 - 2011-12-16:
[KLAROS-1463] - JDBC batching of versioned data breaks concurrent updates
[KLAROS-1462] - NullPointerException after creating issues in Redmine
[KLAROS-1461] - Exception when creating a Bugzilla 4 issue
[KLAROS-1459] - Moving jobs on the maintain jobs pages sometimes does not work if changes are dropped.
[KLAROS-1454] - Result importer fails to create new test cases
[KLAROS-1453] - Problems setting assignee on the Job Details page
[KLAROS-1447] - Entering new credentials while validating an issue management system saves changes
[KLAROS-1345] - Duplicate IDs are generated when saving new test cases simultaneously in different sessions
[KLAROS-1142] - Existing field value changed when rapidly adding new test environments
[KLAROS-1467] - Show a sorted list of issue management systems when selecting
[KLAROS-1464] - When automatically logging into a Bugzilla system, try also with the supplied email address as login
Version 3.4.7 - 2011-11-18:
[KLAROS-1442] - The upload attachment dialog on the test case details page is disabled if the test case is not new.
[KLAROS-1441] - Changed category trees are not updated properly in sessions of other users
[KLAROS-1430] - Unable to recover project backups under Java 7
[KLAROS-1428] - import result type is reset when selecting entries other than 'AUnit'
[KLAROS-1425] - Searching for a user defined property while assigning a test case to a job raises an exception
[KLAROS-1445] - Change the import behavior so that previous projects are no longer overwritten for mutiple imports of the same file
[KLAROS-1437] - Allow every user to execute any job which is not explicitly assigned to another user
[KLAROS-1434] - Show the user defined properties of a test case before executing a test
Version 3.4.6 - 2011-10-17:
[KLAROS-1418] - Unable to link issues after executing a test suite
[KLAROS-1415] - Link to issue management in the Link Issues dialog does not change to reflect the selected IMS
[KLAROS-1414] - The JIRA components field should be flagged as required
[KLAROS-1412] - Unable to authenticate trac user with credentials different from the klaros credentials
[KLAROS-1411] - Unable to create issues in Bugzilla 4.x
[KLAROS-1396] - Custom property values are not accessible in the report model
[KLAROS-1393] - Error uploading MS Documents
[KLAROS-1391] - Trial Expiration on the system information shows 100% instead of days when expired
[KLAROS-1390] - Checking a Trac connection results in an IllegalArgumentException
[KLAROS-1389] - Encoding problem may cause certain characters in user-defined language files to become corrupted
[KLAROS-1388] - Garbled select item boxes in data tables with IE
[KLAROS-1240] - Warning appears in log due to possible hibernate cache miss
[KLAROS-1420] - Speed up IM authentication by reducing the number of reauthentication attempts
[KLAROS-1419] - Show more information about test cases in a test suite prior to execution
[KLAROS-1413] - Provide better exception logging for email render exceptions
[KLAROS-1408] - Optionally show test case details during test execution
Version 3.4.5 - 2011-08-29:
[KLAROS-862] - Duplicate section title for SDK Appendix
[KLAROS-1350] - Test Run History report page must provide a better handling of the situation when no test has yet been executed
[KLAROS-1357] - Missing labels for Bugzilla fields
[KLAROS-1363] - User system account flag can't be changed once user has been created.
[KLAROS-1364] - Perma-URLs return server errors when user session is not present
[KLAROS-1365] - Created issue button in test case runner not enabled until a test suite is run
[KLAROS-1366] - Connecting to secured bugzilla instances fails
[KLAROS-1367] - Creating a job on the Generate Jobs from Test Cases/Suites page while an assignee is selected causes a NullPointerException.
[KLAROS-1368] - Editing test case step summaries or descriptions after a test case has been executed does not store all values in some cases
[KLAROS-1370] - Changing assigned user on the Maintain Jobs page is impossible.
[KLAROS-1378] - Error importing test suite results
[KLAROS-1381] - System users can log in to the application interactively
[KLAROS-1299] - Previous step results are currently discarded if the runner switches between step and tabular view
[KLAROS-1300] - Popups in the test runner should not be as wide as in normal Klaros windows
[KLAROS-1352] - Monospaced text layout in table cells should be improved
[KLAROS-1361] - Make the Klaros launch from the installer optional
[KLAROS-1369] - Allow to add step summary/description at any step even for non error/failure step results
[KLAROS-1374] - Upgrade distribution to Tomcat 6.0.33
[KLAROS-1376] - Improve the documentation about email parameter settings
[KLAROS-1377] - Fix the resizing of HTML GUI Icons
[KLAROS-1383] - Show the number of test case steps when selecting a test to execute
[KLAROS-1385] - Update the redmine integration documentation to enforce the use of the Enable Rest Webservice API switch
Version 3.4.4 - 2011-08-03:
[KLAROS-1355] - Selecting a second issue management system on the link issues page throws a lazy initialisation exception
[KLAROS-1354] - Connection problems to the issue management systems are not properly logged when linking existing issues
[KLAROS-1349] - java.lang.IllegalAccessError upon first application login using some Java VMs
[KLAROS-1348] - Trying to link a non-existing Mantis Issue leads to a NullPointerException
[KLAROS-1341] - Upload file area disabled upon selecting the upload test result page
[KLAROS-1340] - Importing invalid result document lead to a potential exception when trying to import them
[KLAROS-1336] - User defined property enumeration values can be equal.
[KLAROS-1335] - NullpointerException when using a newly associated IM the first time
[KLAROS-1333] - HTTP Status 404 running overview reports
[KLAROS-1327] - Name and description are not consistantly displayed for test cases and test suite in the execute pages and the runner.
[KLAROS-1322] - Missing Label for Mantis Severity field
[KLAROS-1319] - Wrong creator shown for redmine task
[KLAROS-1305] - Global select on jobs from test cases page doesn't work
[KLAROS-1275] - Last modifications not properly tracked report template overview pages
[KLAROS-1127] - Clicking execute on a job does not cause a save unsaved changes dialog to appear
[KLAROS-1114] - Erratic behavior while nesting jobs
[KLAROS-940] - All manually generated error pages of our servlets have an encoding problem
[KLAROS-1356] - List the number of related issues per test case
[KLAROS-1351] - Enable the caching of the list of available projects
[KLAROS-1343] - Show the execution time of executed tests in the result data table
[KLAROS-1339] - Add support for Java 7
[KLAROS-1338] - Make the installer work on MacOS as an unofficially supported platform
[KLAROS-1334] - Unnecessary table size selector for issue trackers in project configuration
[KLAROS-1325] - Support Excel output in the custom report engine
[KLAROS-1306] - Support bulk assignment on maintain jobs page
[KLAROS-1239] - The selected entities on the overview pages must be persisted in the base bean
[KLAROS-1128] - Job execution buttons must differ for test related and non test related jobs
[KLAROS-1105] - Let the user select test cases instead of test case results in the suite execution summary selector box
Version 3.4.3 - 2011-06-24:
New Features:
[KLAROS-1312] - Add support for developing and uploading user defined language files
[KLAROS-1332] - Link Issues should only be available when an issue management system is available
[KLAROS-1331] - Color coded columns in test run result data table
[KLAROS-1330] - Right aligned columns in test suite result data tables
[KLAROS-1324] - Linking Mantis issues silently fails
[KLAROS-1323] - The Mantis integration fails with error 'no viewState with name public' on localized non-English Mantis installations
[KLAROS-1291] - Assigning a job to a parent and then clicking cancel causes a duplicate job to appear in the table
[KLAROS-1288] - Create user screen doesn't allow the status bar to close
[KLAROS-1329] - Improve the rendering of multi-line text fields
[KLAROS-1328] - Add the name of test cases as a tooltip in the table on the test suite results details page.
Version 3.4.2 - 2011-05-27:
[KLAROS-1016] - First page of installer has scrollbars
[KLAROS-1309] - When using multiple Category groups, assigning an entity to a subcategory can cause the entity to disappear from other groups
[KLAROS-1310] - Click on report icons of Dashboard does not open the requested report in IE
[KLAROS-1314] - Test case result bookmarks throw an exception when no session is present and the project is not access protected
[KLAROS-1315] - Database Migration from pre-3.0 installations fails to close result sets
[KLAROS-1316] - Only 10 steps are displayed when viewing test case result details in the evaluate section
[KLAROS-1318] - New test cases and test suites created using bulk duplicate or bulk new revision do not appear in root categories.
[KLAROS-1236] - Add upload option for a user supplied quotes.txt on general settings page
[KLAROS-1287] - confusing revision numbers when migrating DB
[KLAROS-1311] - Update the issue management systems drivers for Bugzilla, Trac, Redmine and Mantis
[KLAROS-1313] - Add the user country setting to the displayed variables on the system settings page
[KLAROS-1317] - Add a more detailed test result import interface documentation
[KLAROS-1320] - Document the different project id fields in the supported issue trackers
Version 3.4.1 - 2011-05-10:
[KLAROS-1307] - Exception when using the insert function for a step on the test case details page
[KLAROS-1304] - Installation process stops on step 9
[KLAROS-1302] - Result fields are not aligned properly on the test case and test suite result print pages.
Version 3.4.0 - 2011-05-03:
New Features:
[KLAROS-1254] - Implement a print function for objects like test case, test suite, test result etc.
[KLAROS-1250] - Allow to filter test runs after SUT/Environment
[KLAROS-1245] - Allow a tabular access to enter test step results
[KLAROS-1229] - Support custom "random quote of the day" file
[KLAROS-1226] - Support HTTP connections through HTTP Proxies
[KLAROS-1213] - Support a command line based installer for the linux distribution
[KLAROS-703] - Allow logical categorization of test items
[KLAROS-642] - Save the result type for every step in the test case result
[KLAROS-487] - Enable bulk actions for filtered items
[KLAROS-1297] - Users logged in as a tester can't use the dropdown box on some pages to change revision
[KLAROS-1289] - Broken layout in the category panel collapsible
[KLAROS-1286] - Cloning a test suite and directly editing leads to test cases not being copied
[KLAROS-1280] - The next and previous buttons on the test case details page load the test cases in the wrong order
[KLAROS-1279] - The position of the Next/Previous buttons on the test case details page depends on the Test Case name length
[KLAROS-1278] - A newly created job on the maintain jobs page doesn't show up in the list
[KLAROS-1277] - RequiredException when using Test Run permalink
[KLAROS-1276] - Creating test case step with no content caused exceptions
[KLAROS-1273] - The drop down box to filter for dynamic enum properties gets not refreshed when updating the property definitions
[KLAROS-1263] - Add a note to the manual that Copy Test Cases is a Enterprise Edition Feature
[KLAROS-1260] - Names of deleted user-defined properties are not properly removed from the system
[KLAROS-1243] - Exception after executing a test suite based job
[KLAROS-1235] - Adding a test case to a test suite while creating a new revision doesn't work
[KLAROS-1234] - Can't purge project from the DB
[KLAROS-1292] - Add back buttons to details pages in Define section
[KLAROS-1281] - Add documentation for JMX monitoring to the user manual
[KLAROS-1271] - Prefill the script and report fields with the default structure when creating a new report template
[KLAROS-1269] - Tried to remove the category from testcases, it is not clear what is going on in that process
[KLAROS-1248] - The list of open test suite executions should show the maximum number of tests in that suite
[KLAROS-1044] - Alignment of arrange icons is messed up on IE8
Version 3.3.2 - 2011-03-18:
Version 3.3.1 - 2011-03-03:
Version 3.3.0 - 2011-02-28:
New Features:
Version 3.2.3 - 2010-12-22:
Version 3.2.2 - 2010-11-23:
Version 3.2.1 - 2010-11-09:
Version 3.2.0 - 2010-11-03:
New Features:
Version 3.1.2 - 2010-10-29:
Version 3.1.1 - 2010-10-01:
Version 3.1.0 - 2010-09-01:
New Features:
Version 3.0.4 - 2010-08-13:
Version 3.0.3 - 2010-08-06:
New Features:
Version 3.0.2 - 2010-07-26:
Version 3.0.1 - 2010-07-19:
New Features:
Version 3.0.0 - 2010-07-16:
New Features:
Verknüpfte Assets
Robert Munteanu, geändert vor 13 Jahren.
Youngling Beiträge: 5 Beitrittsdatum: 02.09.10 Neueste Beiträge
I see that you've updated the integrations for Redmine and Bugzilla for the latest release. I'd like to point out that the upcoming release of Mantis will need a refresh of the SOAP stubs if you are using Axis or similar toolkits.
See https://sourceforge.net/mailarchive/forum.php?thread_name=CAC8ULPaqVDSAUAvbYAx34-OACROV2thypd0y8gC2SFe-N_dM5w%40mail.gmail.com&forum_name=mantisbt-soap-dev for the announcement. I encourage to to subscribe to that low-traffic list to receive notifications about upcoming SOAP changes in MantisBT.
Robert
Hi Robert,
thanks a lot for the heads-up!
We are using the mylyn mantis connector so I guess you might be the right person to ask when a matching update will be available? emoticon
Cheers,
The updated version was released three days ago :-) It's good to know that you're embedding the Mantis connector, I will be more careful when breaking things.
You can also subscribe to the Mylyn-Mantis user forum ( https://sourceforge.net/apps/phpbb/mylyn-mantis/viewforum.php?f=3&sid=3718ca44eacc0eeb33752b54b1d7d355 ) or to my blog ( http://rombertw.wordpress.com/tag/mylyn-mantis/ ) to get notified of new connector released.
Robert
What a pity!
I was checking http://mylyn-mantis.sourceforge.net/ two days ago for relevant updates.
As the Redmine integration will soon have to be changed for their 1.3 release a few days ago as well, I guess the next maintenance update will not be too far away.
I will check the supplied links more often and also contact you soon via PM on matters we encountered during integration (not bugs, just limitations we hit during integration).
And I guess this is the place to say a big Thank You from us all for your efforts on the connector!
You're welcome , I'm happy to hear that my efforts are well-received :-) And by all means, please contact me regarding the limitations you've hit during usage ; the API was never meant to be used outside the Eclipse connector, so it's definitely not aimed towards external usage.
Robert
