RE: Link to System Under Test Attachment(s) from Test Case
Matthias Baudot, geändert vor 4 Monaten.
Youngling Beiträge: 9 Beitrittsdatum: 15.10.24 Neueste Beiträge
I found this in the instructions but it doesn't seem to help: https://www.klaros-testmanagement.com/files/doc/html/User-Manual.Functions.Main.html#User-Manual.Functions.Main.DetailsUserDefined.ReferencingAttachments
Thank you!
Torsten Stolpmann, geändert vor 4 Monaten.
Hello Matthias,
Matthias Baudot, geändert vor 2 Monaten.
Thank you for your reply Torsten, but it is not exactly what I am looking for.
Download the installer here: My SUT Attachment 1My SUT Attachment 2
Does that make sense?
Matthias Baudot, geändert vor 1 Monat.
Thanks in advance.
Torsten Stolpmann, geändert vor 1 Monat.
Hello Matthias,
Hope that clears things up.
Matthias Baudot, geändert vor 19 Tagen.
The issue reported at https://www.klaros-testmanagement.com/en/forum/-/message_boards/view_message/835166 has indeed been fixed in 5.7.1.
Let me try to clarify:
Thank you very much!
Torsten Stolpmann, geändert vor 15 Tagen.
Hello Matthias,
​​​​​​​Torsten
