Klaros-Testmanagement 5.7.0 released - Klaros Test Management - Forum - Klaros-Testmanagement
Torsten Stolpmann, geändert vor 1 Jahr.
We are pleased to announce the release of Klaros Test Management 5.7.0.
This feature release adds several new features, improvements and stability fixes:
Overall this maintenance release provides 5 new features, 17 improvements and 23 bug fixes.
Release Notes Version 5.7.0 (13.12.2024)
New Features
[KLAROS-5334] - Support bulk synchronisation of test cases and test suites
[KLAROS-5339] - Support multiselect custom property fields
[KLAROS-5348] - Support bulk editing of requirement status fields
[KLAROS-5368] - Automatically purge the associated results of a test case or test suite and remove them from their test runs when purging test cases or test suites from a project
[KLAROS-5369] - Support filtering the test cases and test suites shown in the project overview dashboard report by having an associated job in that project
Improvements
[KLAROS-4744] - Add hot key support to the table filter panel
[KLAROS-5244] - Check and improve the guest role limitations in the user interface
[KLAROS-5303] - Allow deleting or purging of test cases and test suites which are linked as a synchronization source in another project by automatically detaching them
[KLAROS-5331] - Optimize search input field input response time
[KLAROS-5335] - In case no requirements are defined in a project, the test run report should list the test case traceability field instead of an (always empty) list of assigned requirements
[KLAROS-5336] - Automatically filter disabled/deleted objects from the configuration report model object lists
[KLAROS-5341] - Revise header/footor export of tables for XLSX and PDF Format
[KLAROS-5350] - Improve documentation on the bulk merge user functionality
[KLAROS-5356] - lnclude inherited members through ancestors groups to the list of assignable GitLab members when creating issues
[KLAROS-5359] - Test steps and segment instances should be immediately purged upon removing them from a test case
[KLAROS-5360] - Revise data table export content settings
[KLAROS-5361] - Improve logged short names for test steps, results and segments
[KLAROS-5363] - Align labels and documentation for test case and system under test issue relations when creating new issues
[KLAROS-5365] - Display informations regarding the origin test case/test suite for synchronized test cases and test suites on their listpages and details pages
[KLAROS-5370] - Count resolved jobs as executed in the dashboard project overview report
[KLAROS-5373] - Support saving details pages by using the enter key in text input fields
[KLAROS-5376] - Update the required windows service option documentation for the Tomcat Java settings
Bug Fixes
[KLAROS-5100] - Deactivation of the second password field is necessary to edit user passwords
[KLAROS-5333] - Inconsistencies when comparing test case execution related dashboard diagrams
[KLAROS-5337] - Server uptime display is showing the accumulated hours but not the days
[KLAROS-5338] - Inactive test case step text fields should have a maximum horizontal border in the test runner interface
[KLAROS-5340] - Custom report parameter list must wrap column for default values
[KLAROS-5342] - The test case and test suite lists are not properly updated when switching between copy and synchronize modes on the project copy objects page
[KLAROS-5344] - The content disposition header field response for downloaded reports or attachments is not properly encoded for filenames contining UTF8 characters
[KLAROS-5345] - When editing multi-list custom report parameter entries the custom report parameter type may get cleared when adding or moving report parameters
[KLAROS-5347] - When selecting test suites from the project list page for very large data base scenerarios a recoverable error message may appear
[KLAROS-5351] - User defined properties of test segment steps are listed in two locations when editing test case steps in the non-tabbed step view
[KLAROS-5353] - It is not possible to sort or filter the available item tables in bulk add to object (test suite / test case / test segment) dialogs
[KLAROS-5354] - When editing a test run save confirmation messages may get displayed several times when the test run is part of a job
[KLAROS-5355] - When executing a test case, the reason for skipping all steps will not be saved when not selected from the drop down list
[KLAROS-5357] - Exception logged when switching transfer project synchronization mode
[KLAROS-5358] - The bulk to test segment dialog does not close upon confirmation when the option to create new test segments is selected
[KLAROS-5364] - Missing icons in the tool internal html documentation / tutorial
[KLAROS-5367] - The results cell link is linking to the wrong result type on the test suite result selection page
[KLAROS-5372] - Restore dashboard report hovering tooltips and fix the horizontal bar layouts
- Support multiple selection fields for user-defined attributes
- Several test cases and test suites can now be bulk synchronizeds across project boundaries
- Permanently removing test cases or test suites no longer requires deleting all their previous test runs
- The project overview dashboard report can now restrict the displayed test cases and test suites to those assigned to jobs
- Over 40 additional improvements and bug fixes
New Features
Improvements
Bug Fixes
