RE: Trac Issue Management Exception after upgrade - Klaros Test Management - Forum - Klaros-Testmanagement
Richard S., geändert vor 14 Jahren.
Youngling Beiträge: 6 Beitrittsdatum: 10.12.10 Neueste Beiträge
Hi there!
I just upgraded my klaros-version to 3.4.5 (Communtiy Edition). The issue managment with trac works fine until I made an upgrade.
When I want to verify the Trac-URL in the issue management in klaros I get an exception in the browser window with this trace:
I use ssl in trac and I imported the certificate with the InstallCert-Tool again.
What has changed after I performed this upgrade?
Richard
#{maintainIssueManagementBean.checkURL(element)}: java.lang.IllegalArgumentException | |
at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:90) | |
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:100) | |
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118) | |
at de.verit.klaros.web.beans.application.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:54) | |
at com.icesoft.faces.webapp.http.core.JsfLifecycleExecutor.apply(JsfLifecycleExecutor.java:18) | |
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.renderCycle(ReceiveSendUpdates.java:132) | |
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.service(ReceiveSendUpdates.java:74) | |
at com.icesoft.faces.webapp.http.core.RequestVerifier.service(RequestVerifier.java:31) | |
at com.icesoft.faces.webapp.http.common.standard.PathDispatcherServer.service(PathDispatcherServer.java:24) | |
at com.icesoft.faces.webapp.http.servlet.BasicAdaptingServlet.service(BasicAdaptingServlet.java:16) | |
at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:23) | |
at com.icesoft.faces.webapp.http.servlet.SessionDispatcher.service(SessionDispatcher.java:53) | |
at com.icesoft.faces.webapp.http.servlet.SessionVerifier.service(SessionVerifier.java:26) | |
at com.icesoft.faces.webapp.http.servlet.MainServlet.service(MainServlet.java:131) | |
at javax.servlet.http.HttpServlet.service(HttpServlet.java:-1) | |
at de.verit.klaros.web.servlet.ExceptionHandlingPersistentFacesServlet.service(ExceptionHandlingPersistentFacesServlet.java:51) | |
at com.icesoft.faces.webapp.xmlhttp.BlockingServlet.service(BlockingServlet.java:56) | |
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:-1) | |
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:-1) | |
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:-1) | |
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:-1) | |
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:-1) | |
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:-1) | |
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:-1) | |
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:-1) | |
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:-1) | |
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:-1) | |
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:-1) | |
at java.lang.Thread.run(Thread.java:662) | |
Caused by: #{maintainIssueManagementBean.checkURL(element)}: java.lang.IllegalArgumentException | |
at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:118) | |
at javax.faces.component.UICommand.broadcast(UICommand.java:387) | |
at com.icesoft.faces.component.panelseries.UISeries$RowEvent.broadcast(UISeries.java:617) | |
at com.icesoft.faces.component.panelseries.UISeries.broadcast(UISeries.java:285) | |
at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:475) | |
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:756) | |
at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:82) | |
at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:102) | |
at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102) | |
Caused by: java.lang.IllegalArgumentException | |
at org.eclipse.mylyn.commons.net.AuthenticationCredentials.<init>(AuthenticationCredentials.java:38) | |
at de.verit.klaros.service.issuemanagement.mylyn.trac.TracIssueManagementService.login(TracIssueManagementService.java:353) | |
at de.verit.klaros.service.issuemanagement.mylyn.trac.TracIssueManagementService.checkAuthentication(TracIssueManagementService.java:415) | |
at de.verit.klaros.service.issuemanagement.connection.IssueManagementConnectionImpl.connectService(IssueManagementConnectionImpl.java:67) | |
at de.verit.klaros.service.issuemanagement.connection.IssueManagementConnectionImpl.<init>(IssueManagementConnectionImpl.java:44) | |
at de.verit.klaros.service.issuemanagement.connection.IssueManagementConnectionPoolImpl.createConnection(IssueManagementConnectionPoolImpl.java:40) | |
at de.verit.klaros.web.beans.session.MylynAuthenticationBean.getConnection(MylynAuthenticationBean.java:102) | |
at sun.reflect.NativeMethodAccessorImpl.invoke0(NativeMethodAccessorImpl.java:-2) | |
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) | |
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) | |
at java.lang.reflect.Method.invoke(Method.java:597) | |
at org.jboss.seam.util.Reflections.invoke(Reflections.java:22) | |
at org.jboss.seam.intercept.RootInvocationContext.proceed(RootInvocationContext.java:32) | |
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:56) | |
at org.jboss.seam.transaction.RollbackInterceptor.aroundInvoke(RollbackInterceptor.java:28) | |
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:68) | |
at org.jboss.seam.core.BijectionInterceptor.aroundInvoke(BijectionInterceptor.java:77) | |
at org.jboss.seam.core.MethodContextInterceptor.aroundInvoke(MethodContextInterceptor.java:44) | |
at org.jboss.seam.core.SynchronizationInterceptor.aroundInvoke(SynchronizationInterceptor.java:32) | |
at org.jboss.seam.intercept.RootInterceptor.invoke(RootInterceptor.java:107) | |
at org.jboss.seam.intercept.JavaBeanInterceptor.interceptInvocation(JavaBeanInterceptor.java:185) | |
at org.jboss.seam.intercept.JavaBeanInterceptor.invoke(JavaBeanInterceptor.java:103) | |
at de.verit.klaros.web.beans.session.MylynAuthenticationBean_$$_javassist_seam_39.getConnection(MylynAuthenticationBean_$$_javassist_seam_39.java:-1) | |
at de.verit.klaros.web.beans.pages.configure.MaintainIssueManagementBean.passwordDialogConnect(MaintainIssueManagementBean.java:129) | |
at de.verit.klaros.web.beans.pages.configure.MaintainIssueManagementBean.checkURL(MaintainIssueManagementBean.java:468) | |
at de.verit.klaros.web.beans.pages.configure.MaintainIssueManagementBean_$$_javassist_seam_79.checkURL(MaintainIssueManagementBean_$$_javassist_seam_79.java:-1) | |
at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:335) | |
at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:280) | |
at org.jboss.el.parser.AstMethodSuffix.getValue(AstMethodSuffix.java:59) | |
at org.jboss.el.parser.AstMethodSuffix.invoke(AstMethodSuffix.java:65) | |
at org.jboss.el.parser.AstValue.invoke(AstValue.java:96) | |
at org.jboss.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:276) | |
at com.sun.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:68) | |
at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:88) | |
Richard
Hi Richard,
from what version did you upgrade from? 3.4.4?
Rgards,
Rgards,
thank you for the fast answer! I upgraded from 3.3.2
Hi Richard,
I've reproduced this issue and it is a bug.
This is being tracked as KLAROS-1390 (Checking a Trac connection results in an IllegalArgumentException) and should be fixed in the next release.
There is a workaround for the connection validation - if a Trac account exists with the username and password used to log into Klaros-Testmanagement, that will be used to test the connection.
I have not encountered this problem while creating or linking issues, so after setting up the Trac connection you should encounter no further problems.
Hi Richard,
Klaros-Testmanagement 3.4.6 has been released today which should finally resolve this problem.
Please send a notice if you experience any more problems.
