Klaros-Testmanagement 5.6.1 released - Klaros Test Management - Forum - Klaros-Testmanagement
Torsten Stolpmann, geändert vor 1 Jahr.
We are pleased to announce the release of Klaros Test Management 5.6.1.
This maintenance release adds several improvements and stability fixes.
Overall this release provides 9 improvements and 13 bug fixes.
Release Notes Version 5.6.1 (30.07.2024)
[KLAROS-5306] - The current iteration should be checked against the defined iteration in the job and optionally changed by the user before starting a job
[KLAROS-5307] - Add missing filter options on various job, test result and issues tables
[KLAROS-5312] - Document how to set the estimated duration attribute when importing test cases via xml
[KLAROS-5314] - Improve the behaviour of detail pages showing objects which are getting purged from the database by another user
[KLAROS-5316] - When displaying a category tree selection always scroll to the selected category node
[KLAROS-5317] - Extend tool tip text of the sut progress information on the iteration details page
[KLAROS-5321] - Avoid logged warning "Monaco Editor requires a resource version to work properly and 'primefaces.HIDE_RESOURCE_VERSION' is currently configured." when navigating to the Template and Script tab on the report template detail page
[KLAROS-5323] - Update Jira rest client implementation to support Jira 10
[KLAROS-5325] - Non-writable issues should not prevent assigning or removing assigned test cases
[KLAROS-5304] - Unable to purge a test case or test suite that is still linked in another project
[KLAROS-5305] - The progress evaluation on the iteration details page always refers to all defined test cases in the project instead of just the test cases from the requirements assigned to the iteration
[KLAROS-5313] - The "time" attribute for teststeps only accepts integers when importing test results
[KLAROS-5315] - Regression: ContextAwareMethodNotFoundException in custom sort option implementations
[KLAROS-5318] - Test cases may potentially get disassociated from requirements when edited on the test case list page
[KLAROS-5320] - Exception when checking user authorization while editing report templates
[KLAROS-5322] - Missing line break in reports if a cell contains more than one element
[KLAROS-5324] - Potential system under test mismatch while initializing the overview diagram on the iteration details page
[KLAROS-5326] - Removing project membership on the project details page for a single user requires a global manager role instead of a project manager role
[KLAROS-5327] - Assigning test cases or system under tests to an issue deleted on the remote issue management system triggers an error
[KLAROS-5328] - Error visiting an object directly from the search result page
[KLAROS-5329] - Back button has no effect when linking an issue from the test suite run summary page in the test client
[KLAROS-5330] - When linking issues on the test suite runner summary page, the list of linked issues does not reflect the assigned issues of the currently selected test case
