cannot start Klaros after 3.4.4 iupgrade
I cannot seem to get the klaros-web url to start without getting 404
I have noticecd in my Tom Cat window. the following message. Not sure what I have done wrong, but I have tried uninstalling completely, everything I can to get it up and running. Still no joy
SEVERE: The web application [/klaros-web] created a ThreadLocal with key of type
[java.lang.ThreadLocal] (value [java.lang.ThreadLocal@1fb75c7]) and a value of
type [org.apache.derby.iapi.services.context.ContextManager] (value [org.apache.
derby.iapi.services.context.ContextManager@1155013]) but failed to remove it whe
n the web application was stopped. This is very likely to create a memory leak.
RE: cannot start Klaros after 3.4.4 iupgrade
Hi Jamie,
the message shown is harmless, indicating a problem while shutting down. Can you please provide the full console log?
P.S.: Having a hunch - Could it be you still have Klaros running as a service in the background?
Hi Torsten.
I attach the tomcat llog
Hi Jamie,
as suspected your derby database is locked by another Klaros instance. Please have a look at other java processes hanging around and try terminate those.
Thanks Torsten. I could not find the rogue process, so due to me having a back up of all my projects and only me using Klaros. I decided to remove the Klaros directories and old Derby database. All back up and running now
