RE: Jenkins and Klaros Automation - Klaros Test Management - Forum - Klaros-Testmanagement
Charlie Beckett, geändert vor 14 Jahren.
Youngling Beiträge: 3 Beitrittsdatum: 03.02.11 Neueste Beiträge
Firstly thanks for a great product.
Would it be possible to change the Jenkins Klaros Plugin so that it allows support for nunit ? If I tweak the config.xml (Jenkins plugin folder) and change the type to nunit, the reports seem to be logged into Klaros accordingly. Unfortunately if you change a project option in Jenkins, this soon gets reset back to JUnit and it fails (although it does report success in the console).
<hudson.plugins.klaros.KlarosTestResultPublisher>
<config>P00003</config>
<env>ENV00003</env>
<sut>SUT00001</sut>
<type>nunit</type>
Thanks.
<env>ENV00003</env>
<sut>SUT00001</sut>
<type>nunit</type>
Thanks.
Klaus Mandola, geändert vor 14 Jahren.
Youngling Beiträge: 2 Beitrittsdatum: 12.02.09 Neueste Beiträge
Hi Charlie,
I created a feature request, "KLAROS-1326 Provide support for nunit in the Jenkins plugin", in our Jira, but
I cannot give a date for delivery yet.
Thank you very much for your input.
Regards, Klaus
Regards, Klaus
RE: Jenkins and Klaros Automation (Antwort)
Hi Charlie,
we have looked further into implementing KLAROS-1326 but unfortunatly the changes for implementing this feature will require additional code on the Klaros side as well as on the plugin side, as the list of supported formats should not be hardcoded in the Jenkins Plugin.
So please have some patience here.
In the mean time you may want to either try to hack your own version of the Klaros Jenkins Plugin with a different hard coded result format (sources are available in the Jenkins SVN) or use the curl based approach as described in the documentation and enter this as an additional build step in the Jenkins job definition:
I know this is far from being a perfect solution but may help you in the meantime.
curl -v -H "Content-Type: text/xml" -T <test result file> \ | |
'<klaros-application-url>/seam/resource/rest/importer?config=P00001&env=ENV00001&sut=SUT00001&type=nunit&time=23.05.2011_14:55' |
