RE: Import from excel(xls) using curl command is not working. - Klaros Test Management - Forum - Klaros-Testmanagement
Bhavesh Soni, geändert vor 1 Jahr.
Youngling Beiträge: 5 Beitrittsdatum: 27.04.23 Neueste Beiträge
I have installed the Klaros community edition for evaluation purposes however, excel import using CURL command is not working. Curl Command:also,I have attached a sample file that I am trying to upload and Project is present. For more details, Please check attached screenshot: Error:Please guide me on how can i import the test cases.
27-Apr-2023 08:33:50.157 INFO [http-nio-18080-exec-7] org.apache.coyote.http11.Http11Processor.service Error parsing HTTP request header Note: further occurrences of HTTP request parsing errors will be logged at DEBUG level. java.lang.IllegalArgumentException: Invalid character found in the request target [/klaros-web/seam/resource/rest/import/testcase/xls?config=P00001\&username=admin&password=Password]. The valid characters are defined in RFC 7230 and RFC 3986 at org.apache.coyote.http11.Http11InputBuffer.parseRequestLine(Http11InputBuffer.java:494) at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:271) at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65) at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:891) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1784) at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191) at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.base/java.lang.Thread.run(Unknown Source)
there was an extra '\' in URL (...config=P00001\&username...).after that I am getting below error
* Trying 127.0.0.1:18080...
> Host: localhost:18080
> User-Agent: curl/7.81.0
> Accept: */*
> Content-Length: 8704
> Expect: 100-continue
< HTTP/1.1 100
< HTTP/1.1 405
< Content-Language: en
< Content-Length: 685
< Connection: close
* Closing connection 0
<!doctype html><html lang="en"><head><title>HTTP Status 405 – Method Not Allowed</title><style type="text/css">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;background-color525D76;} h1 {font-size:22px;} h2 {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a {color:black;} .line {height:1px;background-color525D76;border:none;}</style></head><body><h1>HTTP Status 405 – Method Not Allowed</h1><hr class="line" /><p><b>Type</b> Status Report</p><p><b>Description</b> The method received in the request-line is known by the origin server but not supported by the target resource.</p><hr class="line" /><h3>Apache Tomcat/9.0.71</h3></body></html>
> Accept: */*
< HTTP/1.1 100
< HTTP/1.1 405
< Connection: close
Talal Arif, geändert vor 1 Jahr.
Youngling Beiträge: 2 Beitrittsdatum: 06.01.16 Neueste Beiträge
Hello Bhavesh,
Talal
Talal
File Location:
* Trying localhost:18080...
> Accept: */*
< HTTP/1.1 100
< HTTP/1.1 405
< Connection: close
File Location:
> Accept: */*
< HTTP/1.1 100
< HTTP/1.1 405
< Connection: close
Hello Bhavesh,
-Are you using a proxy?
Talal
Talal
Torsten Stolpmann, geändert vor 1 Jahr.
Hello Bhavesh,
1) Which Klaros version are you using?
2) Are you using a proxy?
My Comments: No
3) Are there any error messages in the Klaros log files during the import attempts?
@Torsten:
1) can you please also list the content of the webapps folder of your installation?
My Comments: We did replace following Jar's jxls-reader-2.0.6.jar and commons-digester3-3.2.jar
My Comments: No
@Torsten:
Hello Bavesh,
1. When using the docker version, your application URL is indeed http://10.100.26.100:18080/ (without klaros-web in the path, this is only required in the standard installer version).
Hello Torsten,
Thank you for your response.
Thank you so much Talal and Torsten.
Thanks and Regards,
Bhavesh Soni
Thanks and Regards,
Bhavesh Soni
Hello Bavenosh,
