Certification connection Error when trying to integrate with Gitlab
Moriz Moo, geändert vor 3 Jahren.
Youngling Beiträge: 7 Beitrittsdatum: 04.12.22 Neueste Beiträge
Hi Torsten! I hope you are well today.
When I try to integrate Klaros into my Gitlab, I received the following error:
Unknown Exception: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
I would be more than happy if you could give me any advice for resolving the issue.
P.S. Please find the error image attached to this message.
Mohammad
RE: Certification connection Error when trying to integrate with Gitlab
Hello Mohammad,
your GitLab instance is using a self-signed SSL certificate, which is not trusted by the Java-VM for security reasons.
The documentation is covering this is Chapter 3.15: https://www.klaros-testmanagement.com/files/doc/html/User-Manual.Installation.SSL.html
You either need to use a certificate that is trusted (e.g. via letsEncrypt.org) or add the certificate to you trusted Java runtime keystore as shown in the documentation.
​​​​​​​The Java Runtime Environment is residing in the jre directory in the istallation folder.
Moriz Moo, geändert vor 2 Jahren.
Hi Torsten!
Thank you for your valuable advice. After referring to the document guide and making changes, the problem was solved.
‌Best,
Mohammad
