RE: Does TestManagement run in OS X? - Klaros Test Management - Forum - Klaros-Testmanagement
I tried, and /klaros-web cannot be deployed in Tomcat Manager. Checked all errors in the logs, and here is the output from localhost.2011.log.
I tried to download all .jar files from http://www.icefaces.org/ and placed them in /lib. No help.
Also it complained about about ch.qos.x.x.x.x too. I download the jar files from http://logback.qos.ch/ and the error went away.
What can I do now? I just download the Community Edition today.
Apr 24, 2011 3:30:00 AM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Error configuring application listener of class com.icesoft.faces.util.event.servlet.ContextEventRepeater
java.lang.NoClassDefFoundError: Could not initialize class com.icesoft.faces.util.event.servlet.ContextEventRepeater
at java.lang.Class.newInstance0(Class.java:355)
at java.lang.Class.newInstance(Class.java:308)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4149)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4704)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:943)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:778)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:504)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1315)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1061)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
at org.apache.catalina.core.StandardService.start(StandardService.java:525)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
SEVERE: Error configuring application listener of class de.verit.klaros.web.listener.SessionTimeoutCustomizingListener
java.lang.NoSuchMethodError: ch.qos.logback.classic.LoggerContext.getBithTime()J
at ch.qos.logback.classic.spi.LoggerContextVO.<init>(LoggerContextVO.java:47)
at ch.qos.logback.classic.LoggerContext.<init>(LoggerContext.java:75)
at org.slf4j.impl.StaticLoggerBinder.<init>(StaticLoggerBinder.java:59)
at org.slf4j.impl.StaticLoggerBinder.<clinit>(StaticLoggerBinder.java:50)
at org.slf4j.LoggerFactory.bind(LoggerFactory.java:121)
at org.slf4j.LoggerFactory.performInitialization(LoggerFactory.java:111)
at org.slf4j.LoggerFactory.getILoggerFactory(LoggerFactory.java:268)
at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:241)
at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:254)
at de.verit.klaros.web.listener.SessionTimeoutCustomizingListener.<clinit>(SessionTimeoutCustomizingListener.java:24)
SEVERE: Skipped installing application listeners due to previous error(s)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1079)
at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:1002)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:506)
Apr 24, 2011 3:30:01 AM org.apache.catalina.core.StandardContext listenerStart
Hi Charles,
what Java version did you use? Klaros requires Java 6 to run.
Although officially we do not support MacOS currently, I saw it running under OS/X.
Hi Torsten
We're running Java 6 on 10.6.7.
It is strange. Some of the exceptions stated No Such Method.
I had 3 problems immediately after installing in OS X 10.6.7.
1. Tomcat cannot find setclasspath.sh
2. Tomcat starts, but Manager cannot load
3. once Manager loads, "/klaros-web" won't load, with a few exceptions in various log files
I had to delete the folder "verit\ Klaros-Testmanagement", and reinstall again with the folder "veritKlaros-Testmanagement".
Then Undeploy "/klaros-web", shutdown Tomcat, delete "klaros-web" from webapps, restart Tomcat, and manually redploy "klaros-web.war".
After a few attempts "klaros-web" finally loads. I can log in.
Will continue to test klaros from here.
RE: Does TestManagement run in OS X? (Antwort)
Charles,
please try out the just released 3.4.4 version, which is finally supposed to install without a glitch on OS X.
Your feedback is welcome.
