RE: Klaros not starting after something happens at midnight
Massimo Dulisse, geändert vor 3 Jahren.
Youngling Beitrag: 1 Beitrittsdatum: 30.06.22 Neueste Beiträge
Hi there,
I have successfully installed Klaros on a virtual server hosted by Ionos and configured it.
​​​​​​​However now something strange is happening - at midnight something happens (I think is Mysql backup); the next morning I find that tomcat is not running and if I restart Klaros I get a SEVERE error message in the logs:
SEVERE [main] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
A couple of questions:
  1. How can I find which listener is failing?
  2. Why the heck the configuration that was working before midnight isn't working if I try to restart Klaros???
TIA,
​​​​​​​Max
Hi Massimo,
Can you please attach the complete log files for analysis?
If this is too big, please feel free to also zip them and send to support@verit.de
Thanks and regards,
​​​​​​​Torsten
Hi Massimo,
Thank you for for sending the logs. The relevant log entry can be found here:
de.verit.klaros.contentrepository.migration.exception.KlarosRepositoryUpgradeException: java.io.IOException: Cannot run program "java": error=2, No such file or directory
    at de.verit.klaros.contentrepository.migration.BaseRepositoryUtil.execute(BaseRepositoryUtil.java:88)
The reason why you see this error is as follows.
​​​​​​​During startup, Klaros forks a separate java Process to compact the file repository before the application will start.
​​​​​​​In your root environment, java is not available, so the startup will fail with above message.
​​​​​​​You rightly may ask, why this is not happening during your initial startup. In this case, the Installer is bringing in it's own Java runtime and a startup initiated from the installer will succeed.
To resolve this, you will need to add a Java runtime to your root account environment.
​​​​​​​In standard Linux installations we do this via systemd like shown below:
[Unit]
Description=Klaros Testmanagement Service
After=syslog.target network.target
[Service]
Environment="JRE_HOME=/opt/klaros-testmanagement/jre"
Environment="PATH=/opt/klaros-testmanagement/jre/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin"
Type=forking
User=klaros
[Install]
WantedBy=multi-user.target
This is documented in the user manual here: https://www.klaros-testmanagement.com/files/doc/html/User-Manual.Installation.installAsService.html#User-Manual.Installation.installAsService.Linux
I am unsure about the steps you took in your Container environment. It may be sufficient to install a Java runtime via your package manager.
​​​​​​​In case you haven't noticed yet, we also provide ready-made docker images here: https://github.com/klaros-testmanagement/klaros-docker/pkgs/container/klaros.
Please let me know if this helps you succeed or require additional information.
