RE: Feature Requests: Line return - Klaros Test Management - Forum - Klaros-Testmanagement
Michaël Erni, geändert vor 11 Jahren.
Hi.
I've a suggestion about Test cases description, Precondition and Postcondition. (Precondition and Postcondition for step too). The possibility to write different informations separate by line return. Like a list.
Exemple - Description:
Test for action XXX for module XXX.
You need to do it 50X.
Exemple - Precondition:
You need:
- 1 PC
- 3 Cables
- 5 Coffees.
Exemple - Postcondition
Result need to:
- Switch on red light
- Change variable BeAware
- Have a result around 50
A presentation like that are more userfriendly than a "One liner" informations.
What do you think about?
Best,
Mike
You need:
- 1 PC
- 3 Cables
- 5 Coffees.
Result need to:
Best,
Mike
Hi Mike,
I agree that this is desirable. We already have the improvement request KLAROS-748 (Text boxes of the test case steps are too small) which was raised here a few weeks ago, describing a similar issue.
This is scheduled for the next feature release (3.1.0). I raised the priority.
Peter Sundell, geändert vor 14 Jahren.
Youngling Beiträge: 2 Beitrittsdatum: 04.02.11 Neueste Beiträge
I'm evaluating your system for a customer. The line feed/manual line breaks is really important to them. When can we expect the release?
Regards // Peter S
Regards // Peter S
Hi Peter,
the implementation is already done (see attached screenshots). The next release is scheduled in about two weeks.
Please contact support@verit.de if you need access to a preview installation.
One more thing just to make sure...
The set line breaks will be seen also when executing the tests?
Regards // Peter S
Regards // Peter S
Yes, definitly. There might be the need to use scrollbars though.
Regards, Torsten
Regards, Torsten
Hi Peter,
we have just released version 3.3 where your issues are hopefully resolved. Plese drop a note if you are stilling missing anything.
