RE: TRAC Integration help
Jamie Gagnon, geändert vor 11 Jahren.
Hi there,
Hi Jamie,
Thanks for your input
HTH,
Morning Torsten.
KLAROS
Jamie
Morning Jamie,
thanks for clearing things up emoticon
It is possible that:
We seem to be on TRAC 0.12
Good Morning
RE: TRAC Integration help (Antwort)
Hi Jamie,
2010-10-13 12:54:06,043 Trac[main] DEBUG: Dispatching <Request "POST '/xmlrpc'">
2010-10-13 12:54:06,046 Trac[cache] DEBUG: cache metadata undefined (youngest_rev=0)
2010-10-13 12:54:06,046 Trac[cache] INFO: repos rev [0] != cached rev [None]
2010-10-13 12:54:06,046 Trac[api] INFO: Synchronized '' repository in 0.00 seconds
2010-10-13 12:54:06,046 Trac[web_ui] DEBUG: RPC incoming request of content type 'text/xml' dispatched to <tracrpc.xml_rpc.XmlRpcProtocol object at 0xdb69dd0>
2010-10-13 12:54:06,046 Trac[web_ui] DEBUG: RPC(XML-RPC) call by 'anonymous'
2010-10-13 12:54:06,047 Trac[xml_rpc] DEBUG: RPC(xml) call by 'anonymous', method 'ticket.component.getAll' with args: ()
2010-10-13 12:54:06,047 Trac[session] DEBUG: Retrieving session for ID '3d009e75afdbaff2095d14f8'
2010-10-13 12:54:06,048 Trac[perm] DEBUG: No policy allowed anonymous performing XML_RPC on None
2010-10-13 12:54:06,048 Trac[web_ui] ERROR: RPC(XML-RPC) Error
Traceback (most recent call last):
  File "/opt/python/lib/python2.6/site-packages/TracXMLRPC-1.1.0_r9171-py2.6.egg/tracrpc/web_ui.py", line 149, in _rpc_process
    req.perm.require('XML_RPC') # Need at least XML_RPC
  File "build/bdist.linux-x86_64/egg/trac/perm.py", line 576, in require
    raise PermissionError(action, resource, self.env)
PermissionError
Regards, Torsten
Hi Jamie,
I really had high hopes that the Trac issues are fully resolved now emoticon
Thanks to you and your team for your efforts on this one. emoticon
You see me relieved emoticon
We will have to look into this. Generally spoken, new features are driven by customer demands. emoticon
