RE: TRAC Integration help - Klaros Test Management - Forum - Klaros-Testmanagement
Jamie Gagnon, geändert vor 11 Jahren.
Hi there,
Hi Jamie,
Thanks for your input
HTH,
HTH,
Morning Torsten.
KLAROS
Jamie
KLAROS
Jamie
Morning Jamie,
thanks for clearing things up
It is possible that:
We seem to be on TRAC 0.12
Good Morning
RE: TRAC Integration help (Antwort)
Hi Jamie,
Regards, Torsten
2010-10-13 12:54:06,043 Trac[main] DEBUG: Dispatching <Request "POST '/xmlrpc'"> | |
2010-10-13 12:54:06,046 Trac[cache] DEBUG: cache metadata undefined (youngest_rev=0) | |
2010-10-13 12:54:06,046 Trac[cache] INFO: repos rev [0] != cached rev [None] | |
2010-10-13 12:54:06,046 Trac[api] INFO: Synchronized '' repository in 0.00 seconds | |
2010-10-13 12:54:06,046 Trac[web_ui] DEBUG: RPC incoming request of content type 'text/xml' dispatched to <tracrpc.xml_rpc.XmlRpcProtocol object at 0xdb69dd0> | |
2010-10-13 12:54:06,046 Trac[web_ui] DEBUG: RPC(XML-RPC) call by 'anonymous' | |
2010-10-13 12:54:06,047 Trac[xml_rpc] DEBUG: RPC(xml) call by 'anonymous', method 'ticket.component.getAll' with args: () | |
2010-10-13 12:54:06,047 Trac[session] DEBUG: Retrieving session for ID '3d009e75afdbaff2095d14f8' | |
2010-10-13 12:54:06,048 Trac[perm] DEBUG: No policy allowed anonymous performing XML_RPC on None | |
2010-10-13 12:54:06,048 Trac[web_ui] ERROR: RPC(XML-RPC) Error | |
Traceback (most recent call last): | |
File "/opt/python/lib/python2.6/site-packages/TracXMLRPC-1.1.0_r9171-py2.6.egg/tracrpc/web_ui.py", line 149, in _rpc_process | |
req.perm.require('XML_RPC') # Need at least XML_RPC | |
File "build/bdist.linux-x86_64/egg/trac/perm.py", line 576, in require | |
raise PermissionError(action, resource, self.env) | |
PermissionError |
Regards, Torsten
Hi Jamie,
I really had high hopes that the Trac issues are fully resolved now
Thanks to you and your team for your efforts on this one.
You see me relieved
We will have to look into this. Generally spoken, new features are driven by customer demands.
