RE: Codepage Issue - Klaros Test Management - Forum - Klaros-Testmanagement
RE: Codepage Issue
Murat H Korkmazov, geändert vor 11 Jahren.
Codepage Issue
Youngling Beiträge: 9 Beitrittsdatum: 26.08.10 Neueste Beiträge
Hi there,
Our team use Redmine as the bug-tracking system and your solution is a must have addon to Redmine.
The major problem although for me (and I guess for someone also) is a luck national code pages support.
For example if I tried to create and describe a test-case in Russian it saves ??????? instead of the national symbols.
Could you please tell me if you plan to add support for non-English Code Pages?
Keep up the good work!
BR,
Murat
BR,
Murat
RE: Codepage Issue
Hi Murat,
welcome and thanks for your kind words.
Klaros should already be able to cope with non-English Code Pages.
I suspect that the data base you are using is not able to handle your national symbols.
What kind of database are you using? Is it configured for handling UTF8-Unicode (or your national codepage)?
RE: Codepage Issue
Torsten, thanks for the prompt reply.
I am playing with demo link that I found on your site:
http://www.klaros-testmanagement.com/demo/pages/homeExecute.seam?conversationId=13
BR
Murat
BR
Murat
RE: Codepage Issue
Now this is embarrassing ...
We will change the collation today (it's swedish latin 1 at the moment)
Thanks for pointing this out!
RE: Codepage Issue
Great! Thanks.
Heiner Westphal, geändert vor 11 Jahren.
RE: Codepage Issue
Hello Murat,
our database uses utf8 encoding now (and collation sequence utf8_general_ci),
as it should have been all the time.
Tests with Indonesian and Cyrillic chars worked ok.
Thank you for pointing this out,
Heiner
P.S.: MySQL >= 5.0 makes it quite easy to transform character data:
does it.
For all tables in a DB I did (in a bash on linux):
we use
character-set-server=utf8
collation-server=utf8_general_ci
in /etc/my.cnf, in section mysqld
Heiner
ALTER TABLE mytable CONVERT TO CHARACTER SET utf8; |
does it.
mysql -B -s -e "show tables" myDB | \ | |
awk '{printf "ALTER TABLE %s CONVERT TO CHARACTER SET utf8;\n",$1}' | \ | |
mysql -B -s myDB |
we use
RE: Codepage Issue
Hi Heiner and Torsten,
Thanks for your prompt response!
I really appreciate it.
BR
Murat
BR
Murat
