RE: Invalid initial heap size Exception when building new Container
Gunnar G H Finkeldeh, geändert vor 4 Jahren.
Youngling Beiträge: 6 Beitrittsdatum: 18.06.21 Neueste Beiträge
Exception on start up:
creating /data/mysql-data
creating /data/klaros-home
creating /data/catalina-base
creating /data/catalina-base/temp
creating /data/catalina-base/logs
creating link /data/catalina-base/conf
creating link /data/catalina-base/webapps
creating link /data/mysql-data/error.log
ln: failed to create symbolic link '/var/log/mysql/error.log': No such file or directory
NOTE: Picked up JDK_JAVA_OPTIONS:  --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
Invalid initial heap size: -Xmsm
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
# Minimum available RAM in MB
MEMORY_MIN=256
# Maximum available RAM in MB
MEMORY_MAX=1024
ENV TOMCAT_MEMORY_MIN 256
# Maximum available RAM in MBENV TOMCAT_MEMORY_MAX 1024
Hello Gunnar,
Can you please check this?
Quick Update:
Hi Gunnar,
Basically you should  just go the directory of choice, edit the .env file and use docker-compose build to build your image.
Following this documentation: https://github.com/klaros-testmanagement/klaros-docker/blob/master/Documentation.adoc worked beautifully!
Thank you again
Gunnar
