RE: Invalid initial heap size Exception when building new Container - Klaros Test Management - Forum - Klaros-Testmanagement
Gunnar G H Finkeldeh, geändert vor 4 Jahren.
Youngling Beiträge: 6 Beitrittsdatum: 18.06.21 Neueste Beiträge
Exception on start up:
creating /data/mysql-data | |
creating /data/klaros-home | |
creating /data/catalina-base | |
creating /data/catalina-base/temp | |
creating /data/catalina-base/logs | |
creating link /data/catalina-base/conf | |
creating link /data/catalina-base/webapps | |
creating link /data/mysql-data/error.log | |
ln: failed to create symbolic link '/var/log/mysql/error.log': No such file or directory | |
NOTE: Picked up JDK_JAVA_OPTIONS: --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED | |
Invalid initial heap size: -Xmsm | |
Error: Could not create the Java Virtual Machine. | |
Error: A fatal exception has occurred. Program will exit. |
# Minimum available RAM in MB | |
MEMORY_MIN=256 | |
# Maximum available RAM in MB | |
MEMORY_MAX=1024 |
ENV TOMCAT_MEMORY_MIN 256
# Maximum available RAM in MBENV TOMCAT_MEMORY_MAX 1024
Hello Gunnar,
Can you please check this?
Quick Update:
Hi Gunnar,
Basically you should just go the directory of choice, edit the .env file and use docker-compose build to build your image.
Following this documentation: https://github.com/klaros-testmanagement/klaros-docker/blob/master/Documentation.adoc worked beautifully!
Thank you again
Gunnar
Thank you again
Gunnar
