RE: Can not generate PDF (exception) for TCR-table with filters applied - Klaros Test Management - Forum - Klaros-Testmanagement
Crosby Dome, geändert vor 4 Jahren.
Youngling Beiträge: 2 Beitrittsdatum: 28.11.20 Neueste Beiträge
Environment and versions: Operating System: Name: Linux Version: 3.10.0-1127.19.1.el7.x86_64 Architecture: amd64 Java: Version: 11.0.8 Vendor: AdoptOpenJDK Home: /root/klaros-testmanagement/jre Runtime Name: OpenJDK Runtime Environment Runtime Version: 11.0.8+10 VM Name: OpenJDK 64-Bit Server VM VM Version: 11.0.8+10 Database: Name: PostgreSQL Version: 12.4 Driver Name: PostgreSQL JDBC Driver Driver Version: 42.2.16 Version: Installed Version: 5.0.3 - Build 4876 (2020-10-14 19:46:29) Release Date: 10/14/2020 Latest available Version: "" Home: /data/klaros-home/ License: Community Edition Installed via: https://github.com/klaros-testmanagement/klaros-docker/blob/master/Documentation.adoc
StepsToReproduce:
- Navigate to "Evaluate"->"TestCaseResults"
- Click on filter button
- Setup filters:
- Field = "Test Suite"
- Type = "Equals"
- Value = "TestSuiteName"
- Click on "Apply" button
- Click on "Export table" button
- Choose "PDF Export"
**BUG:**
"Well, this is unexpected ..." page shows up.
**Exception line:**
`The number of columns in PdfPTable constructor must be greater than zero.`
P.S.: Is there ability on your forum to attach files? I have additional, may be, useful files to help analyze problem (screenshots, video/screencast, logs)
StepsToReproduce:
- Setup filters:
- Type = "Equals"
**BUG:**
**Exception line:**
Hi Crosby,
thanks for reporting this issue.
I tried, but was not able to reproduce this behavior yet. I would be glad if you could add the log file (logs/catalina.out) and a screenshot of the page before exporting to your post.
Yes, this forum allows attachments, but you probably missed the buttons further below. I added a screenshot for clarification.
RE: Can not generate PDF (exception) for TCR-table with filters applied (Antwort)
Hi Crosby,
Klaros-Testmanagement 5.0.0 up to version 5.0.3 had an issue where applying a filter could cause the table to temporarily disappear. This in turn causes the table exporter to fail.
As this has been fixed as KLAROS-4461 in version 5.0.4, I would recommend that you upgrade to that version:
https://github.com/klaros-testmanagement/klaros-docker#update
Thank you so much!
