Klaros-Testmanagement 5.0.2 released
We are pleased to announce the release of Klaros-Testmanagement 5.0.2!
This is a maintenance release that fixes an issue when migrating existing content repositories and adds several other small improvements and stability fixes.
In this release 7 new improvements have been added and 11 bugs have been fixed. Existing users are encouraged to update.
Dashboard
Usability
  • Descriptions for test cases, test steps, etc. are now editable as rich text and may contain images
  • Table contents can be edited directly in the individual cells via mouse click
  • Frequently used functions can be triggered by keyboard shortcuts
  • List entries can be reordered by drag-and-drop
  • Table sorting by clicking on the corresponding column header
  • Bookmarks can be copied directly to the clipboard
Reporting
  • Dashboard contents can now be individually configured and saved. Individual dashboards can be defined as project presets and shared with other users
  • The predefined reports have been completely revised and new reports have been added
  • The diagram display has been significantly accelerated by asynchronous loading
  • Dashboard diagrams can be exported as image files for further processing
  • Data tables can now also be exported in XML and PDF formats
  • Print pages optionally contain additional diagrams
Performance:
  • Database layout has been optimized and database access has been completely reworked
  • Batch transactions, especially for write operations, are now processed substantially faster
Installation
  • The Java runtime environment is now integrated and automatically installed.
  • Klaros uses the current LTS (Long Term Support) Java Runtime Environment Version 11
  • The Tomcat application server has been updated to the current version 9
Databases
  • The MySQL database is now also supported in version 8.
Release Notes
Version 5.0.2 (12.10.2020)
Improvements
[KLAROS-4421] - Show the jobs of an iteration, test environment or system under test as tab in the corresponding details view
[KLAROS-4443] - Support cloning of notification schemes
[KLAROS-4456] - Sub jobs of type 'task' should be considered when determining the progress and status of the parent job
[KLAROS-4468] - Parent job progress calculation should be based on the actual progress rate of its subjobs
[KLAROS-4472] - Gracefully handle SizeLimitExceptions for large LDAP user lists
[KLAROS-4479] - Improve error handling when a distinghuished name for a user could not be found during LDAP/AD authentication
[KLAROS-4487] - Show a progress bar for long running actions in the test runner window
[KLAROS-4494] - Support page size selection on the custom report tables
Fixes
[KLAROS-4467] - Generating jobs from test suites may fail if the test suite name is overly long
[KLAROS-4469] - The installer does not display the current release notes
[KLAROS-4475] - Fix migrating existing Klaros 4 content repositories
[KLAROS-4476] - DataException when accessing overly long text fields of a migrated PostgreSQL database
[KLAROS-4481] - OptimisticLockException when finishing or skipping a test case in a test suite
[KLAROS-4484] - Unable to change the email adress of an administrator account
[KLAROS-4485] - Broken layout in application update available notification icon
[KLAROS-4488] - Unable to save redmine customfields of format "User" or "Version" when not explicitly set when saving an issue
[KLAROS-4489] - The job execution state on job tabs is not determined correctly
[KLAROS-4496] - Error 'Null key requested for object of class de.verit.klaros.core.persistent.TestCaseStepShadow' after editing a test case step result on the test case result page
[KLAROS-4497] - Issue details page layout adds unnecessary horizontal scrollbar
Version 5.0.1 (18.09.2020)
Improvements
[KLAROS-4381] - Reopening a job should propagate updated status, success rate and progress information to its parent job
Fixes
[KLAROS-4460] - Opening the Edit Categories panel fails if the table has unsaved changes
[KLAROS-4459] - Notification Schemes cannot be deleted
[KLAROS-4386] - Reopening a job via bulk edit doesn't automatically reopen its sub jobs
Version 5.0.0 (14.09.2020)
New Features
Improvements
Fixes
