RE: Is it possible to import test cases with community edition?
Alvis Chen, geändert vor 6 Jahren.
Youngling Beiträge: 2 Beitrittsdatum: 26.11.19 Neueste Beiträge
I want to import test cases from excel, but I cannot find where the import function is.
Hi Alvis,
yes, it is possible to import test cases from Excel files into Klaros-Testmanagement. The procedure, as well as the tools needed, are described in our documentation:
https://www.klaros-testmanagement.com/files/doc/html/User-Manual.Import-Export.html#User-Manual.Import-Export.Import-Test-Cases-From-Excel
Please note that the Excel files need to be in a specific format:
https://www.klaros-testmanagement.com/files/doc/html/User-Manual.Import-Export.html#User-Manual.Import-Export.Import-Test-Cases-From-Excel.Format
Thank you for your answer, but in fact, I can't find the entry to execute import test cases.
RE: Is it possible to import test cases with community edition? (Antwort)
Hi again,
the import execution is described in Chapter 12.3.3 of the documentation:
https://www.klaros-testmanagement.com/files/doc/html/User-Manual.Import-Export.html#User-Manual.Import-Export.Import-Requirements-From-Excel.Execution
Basically, you need a command line REST-client (like curl) which does send the Excel files to the import interface of Klaros-Testmanagement.
