Support for UTF-8 (Arabic character set)
Musa Haidari, geändert vor 6 Jahren.
Dear team,
Thank you in advance.
RE: Support for UTF-8 (Arabic character set) (Antwort)
Dear Musa,
Dear Torsten,
@@character_set_database
@@collation_database
Musa Haidari
Dear Musa,
