Creating Jobs From JIRA Tickets
Erinc Cagri Ozcicek, geändert vor 6 Jahren.
Youngling Beiträge: 4 Beitrittsdatum: 01.04.19 Neueste Beiträge
Thank You,
Best Regards
Cagri
RE: Creating Jobs From JIRA Tickets
Hi Erinc,
(Note: the Jira filter API is currently not supported here, but it is in our backlog as KLAROS-3135. But you can already limit the issue types that should be synchronized)
Hi Fabian,
Thank you for your support.
Hi Erinc,
Best Regards,
Cagri
RE: Creating Jobs From JIRA Tickets (Antwort)
Hi Erinc,
you're welcome! Please let us know if it worked after upgrading Jira and/or if you need additional help.
Hi Erinc,
We have  JIRA filters containing tickets regarding to changed software product parts. With these tickets we want create test exexcution jobs that contains the regression tests that are related with changed software parts.
Best Regards,
