Oracle Database - Klaros Test Management - Forum - Klaros-Testmanagement
Oracle Database
Jacopo Doria, geändert vor 8 Jahren.
Oracle Database
Youngling Beitrag: 1 Beitrittsdatum: 11.05.17 Neueste Beiträge
I tried to change the default db from derby to Oracle.
I followed the tutorial I found here (http://klaros-testmanagement.com/en/) but I have always this error message in log file:
According to the guide, I set the number of open_cursor to 2000 (even if I think this is an horrible suggestion...), but without any result.
Could you help me?
2017-05-11 17:53:42: INFO, org.hibernate.dialect.Dialect HHH000400: Using dialect: org.hibernate.dialect.Oracle10gDialect | |
2017-05-11 17:53:43: INFO, org.hibernate.validator.internal.util.Version HV000001: Hibernate Validator 4.3.2.Final | |
2017-05-11 17:53:44: INFO, org.hibernate.search.Version HSEARCH000034: Hibernate Search 4.5.3.Final | |
2017-05-11 17:53:57: WARN, org.hibernate.engine.jdbc.spi.SqlExceptionHelper SQL Error: 1000, SQLState: 72000 | |
2017-05-11 17:53:57: ERROR, org.hibernate.engine.jdbc.spi.SqlExceptionHelper ORA-01000: maximum open cursors exceeded | |
2017-05-11 17:53:57: ERROR, org.hibernate.tool.hbm2ddl.SchemaUpdate HHH000299: Could not complete schema update | |
java.lang.NullPointerException: null | |
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:126) | |
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:112) | |
at org.hibernate.tool.hbm2ddl.DatabaseMetadata.getTableMetadata(DatabaseMetadata.java:158) | |
at org.hibernate.cfg.Configuration.generateSchemaUpdateScriptList(Configuration.java:1283) | |
at org.hibernate.tool.hbm2ddl.SchemaUpdate.execute(SchemaUpdate.java:237) | |
at org.hibernate.tool.hbm2ddl.SchemaUpdate.execute(SchemaUpdate.java:203) | |
at org.hibernate.internal.SessionFactoryImpl.<init>(SessionFactoryImpl.java:522) | |
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1859) | |
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1930) | |
at org.springframework.orm.hibernate4.LocalSessionFactoryBuilder.buildSessionFactory(LocalSessionFactoryBuilder.java:372) | |
at org.springframework.orm.hibernate4.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:454) | |
at de.verit.klaros.core.dao.hibernate.KlarosLocalSessionFactoryBean.buildSessionFactory(KlarosLocalSessionFactoryBean.java:68) | |
at org.springframework.orm.hibernate4.LocalSessionFactoryBean.afterPropertiesSet(LocalSessionFactoryBean.java:439) | |
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1637) | |
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1574) | |
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545) | |
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482) | |
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306) | |
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230) | |
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302) | |
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197) | |
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351) | |
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108) | |
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1481) | |
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1226) | |
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:543) | |
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:772) | |
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:839) | |
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:538) | |
at org.jboss.seam.ioc.spring.ContextLoader.startupContextLoader(ContextLoader.java:64) | |
at org.jboss.seam.ioc.spring.ContextLoader.create(ContextLoader.java:43) | |
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) | |
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) | |
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) | |
at java.lang.reflect.Method.invoke(Method.java:606) | |
at org.jboss.seam.util.Reflections.invoke(Reflections.java:22) | |
at org.jboss.seam.util.Reflections.invokeAndWrap(Reflections.java:144) | |
at org.jboss.seam.Component.callComponentMethod(Component.java:2313) | |
at org.jboss.seam.Component.callCreateMethod(Component.java:2236) | |
at org.jboss.seam.Component.newInstance(Component.java:2196) | |
at org.jboss.seam.contexts.Contexts.startup(Contexts.java:343) | |
at org.jboss.seam.contexts.Contexts.startup(Contexts.java:335) | |
at org.jboss.seam.contexts.Contexts.startup(Contexts.java:317) | |
at org.jboss.seam.contexts.ServletLifecycle.endInitialization(ServletLifecycle.java:143) | |
at org.jboss.seam.init.Initialization.init(Initialization.java:813) | |
at org.jboss.seam.servlet.SeamListener.contextInitialized(SeamListener.java:36) | |
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4853) | |
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5314) | |
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:145) | |
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:753) | |
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:729) | |
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717) | |
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:940) | |
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1816) | |
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471) | |
at java.util.concurrent.FutureTask.run(FutureTask.java:262) | |
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) | |
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) | |
at java.lang.Thread.run(Thread.java:745) | |
2017-05-11 17:53:58: WARN, org.hibernate.engine.jdbc.spi.SqlExceptionHelper SQL Error: 942, SQLState: 42000 | |
2017-05-11 17:53:58: ERROR, org.hibernate.engine.jdbc.spi.SqlExceptionHelper ORA-00942: table or view does not exist |
Could you help me?
RE: Oracle Database (Antwort)
Hi Jacopo,
This is a bug in the distributed oracle driver (ojdbc7 12.1.0.2.0). See https://community.oracle.com/thread/3682300
Remove the driver webapps/klaros-web/WEB-INF/libs/ojdbc7-12.1.0.2.0.jar and add the attached jar, then restart your tomcat server.
We will change this in the upcoming 4.7.0 release.
