RE: Listening only on local IPv6 address - Klaros Test Management - Forum - Klaros-Testmanagement
Robert Gröber, geändert vor 12 Jahren.
Hello
tcp6 0 0 :::18080 :::* LISTEN
robig
robig
test-ubuntu:/opt/klaros$ wget --no-proxy -O - http://10.40.21.62:18080/klaros-web | |
--2010-05-21 11:49:35-- http://10.40.21.62:18080/klaros-web | |
Connecting to 10.40.21.62:18080... connected. | |
HTTP request sent, awaiting response... 400 Bad Request | |
2010-05-21 11:49:35 ERROR 400: Bad Request. |
Heiner Westphal, geändert vor 12 Jahren.
Heiner Westphal
Heiner Westphal
Ive tried to set that property but didn't work
Same issue as before.
Ubuntu-Forums: Disable IPv6
looks most promising to me.
Best Regards,
Heiner Westphal
Best Regards,
Heiner Westphal
Robert,
Hope this helps.
Hope this helps.
