RE: ip address - Klaros Test Management - Forum - Klaros-Testmanagement
RE: ip address
Avery Jacobson, geändert vor 9 Jahren.
ip address
Youngling Beiträge: 5 Beitrittsdatum: 16.05.16 Neueste Beiträge
I have used other case management tools and all I had to do to access them from another computer was to type in the IP address from another computer to access the application; however, when I tried with this application it did not work. How can I do an install on a computer and access it through other computers on a network?
RE: ip address (Antwort)
Hi Avery,
the URL depends upon the parameters you have entered at installation time and is explained in Section 3.8 of the user manual: http://www.klaros-testmanagement.com/demo/doc/User-Manual.Installation.html#User-Manual.Installation-Process.Main.Run-Klaros
If you have changed nothing during the installation the URL for localhost should be: http://localhost:18080/klaros-web. Replace localhost with your ip address for remote access.
RE: ip address
Thanks, normally I just have to put the IP address but when I replaced localhost with the IP and kepted the port and other stuff that worked, thanks.
We do not choose this approach deliberatly, as this would require access to port 80 on the server machine.
This port is often already taken by local IIS or Apache Web server installation and also would require root access on Linux machines.
For production use you may change to the default port 80 by using mod_proxy or similar mechanisms in your web server installation.
