RE: Problems with Hudson Plugin
Toralf Babel, geändert vor 11 Jahren.
Youngling Beiträge: 4 Beitrittsdatum: 08.03.10 Neueste Beiträge
it's me again.
I tried to check out the Hudson-Plugin.
There is a problem with exporting the Testcases from Hudson to klaros.
I get the following error in the console of Hudson:
Export of TEST-de.xxx.xxx.util.MailBodyHelperTest.xml failed - Response status code: 404 for request URL: http://dev-tb:18080/klaros-web//seam/resource/rest/importer?config=P00010&env=ENV00001&sut=SUT00001&type=junit
Finished: SUCCESS
So what might I have done wrong or forgot to configure?
Klaros version 2.5.2
Hudson-Plugin version 1.0
Hi Toralf,
Please try to remove the trailing slash from you server URL you have configured in Hudson. This avoids the double slash in the URL.
Oh thx,
I didn't recognize the slash. ;-)
Toralf
RE: Problems with Hudson Plugin (Antwort)
Been there - done that emoticon
Actually we should improve the URL checking code in the Hudson plugin with the next release.
