RE: Problems with Hudson Plugin - Klaros Test Management - Forum - Klaros-Testmanagement
Toralf Babel, geändert vor 11 Jahren.
Youngling Beiträge: 4 Beitrittsdatum: 08.03.10 Neueste Beiträge
it's me again.
I tried to check out the Hudson-Plugin.
There is a problem with exporting the Testcases from Hudson to klaros.
I get the following error in the console of Hudson:
Export of TEST-de.xxx.xxx.util.MailBodyHelperTest.xml failed - Response status code: 404 for request URL: http://dev-tb:18080/klaros-web//seam/resource/rest/importer?config=P00010&env=ENV00001&sut=SUT00001&type=junit
Finished: SUCCESS
So what might I have done wrong or forgot to configure?
Klaros version 2.5.2
Hudson-Plugin version 1.0
it's me again.
Finished: SUCCESS
Hi Toralf,
Please try to remove the trailing slash from you server URL you have configured in Hudson. This avoids the double slash in the URL.
Oh thx,
I didn't recognize the slash. ;-)
Toralf
Toralf
RE: Problems with Hudson Plugin (Antwort)
Been there - done that
Actually we should improve the URL checking code in the Hudson plugin with the next release.
