Cannot get access to the application from remote host on the network
Brenda Cooney, geändert vor 12 Jahren.
Youngling Beiträge: 4 Beitrittsdatum: 29.01.10 Neueste Beiträge
Hi -
I've created a virtual machine with Centos as an operating system. I installed klaros on it. Klaros installs Tomcat 6, which can act as a web server. I can see and use klaros, in Firefox, from the virtual machine it sits on. I need to be able to access the machine from other hosts on the network.
So, klaros is installed on 'klaros-VM'. I can access it through the web, on that machine, thru' http://localhost:18080/klaros-web/ and http://<ip_address>:18080/klaros-web/
I have another machine on the network 'bren-WM'. I need to be able to access 'klaros-VM' from this machine. When I enter http://<ip_address>:18080/klaros-web/ into my browser, I get:
Unable to connect
Firefox can't establish a connection to the server at <ip-address>:18080.
* The site could be temporarily unavailable or too busy. Try again in a few
moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
<ip-address> Is the IP address of the machine klaros sits on.
Can you tell me if this has something to do with the way klaros sets up Tomcat?
Many Thanks,
Brenda
RE: Cannot get access to the application from remote host on the network
I figured out what I needed to do. After downloading nmap, I discovered that the port 18080 was not open. I opened the Firewall settings and opened port 18080.
Thanks anyway,
Brenda
RE: Cannot get access to the application from remote host on the network (Antwort)
Hi Brenda,
good to hear you were able to help yourself, sorry but you found out the solution too fast for us to answer emoticon
