Import from other data sources
Andreas Arens, geändert vor 12 Jahren.
Youngling Beitrag: 1 Beitrittsdatum: 22.01.10 Neueste Beiträge
Hallo!
Im Flyer über Klaros heißt es:
"Der Import von bereits vorhandenen Daten aus anderen Quellen, wie beispielsweise Excel-Sheets oder anderen Testtools ist möglich."
Leider kann ich da keine weitergehenden Informationen finden. Ist diese Funktionalität nur für die Enterprise Edition vorbehalten?
Vielen Dank,
Andreas Arens
RE: Import from other data sources (Antwort)
Hallo!
Vielen Dank,
Andreas Arens
Rough translation (for our foreign readers):
Hello!
The flyer about Klaros says:
"The import of existing data from other sources, such as Excel sheets, or other testing tools is possible."
Unfortunately, I can find no further information. is that functionality reserved only for the Enterprise Edition?
Thank you very much,
Andreas Arens
Hello!
The "restore backup" function in the 'Configure' section currently allows to import arbitrary project data via XML.
As soon as we have finalized the backup format it will be specified in the manual. The current format is straightforward, so you may consider analyzing the export format in the meantime and write your own transformation.
Dedicated import filters for individual formats/tools will be part of the Enterprise Edition.
If you need support for implementing data transformations for a particular format please contact sales@verit.de for an individual offer.
