RE: Problem with issue management system - Mantis - Klaros Test Management - Forum - Klaros-Testmanagement
Kevin Suess, geändert vor 10 Jahren.
Youngling Beitrag: 1 Beitrittsdatum: 05.08.15 Neueste Beiträge
Hello!
I´m testing klaros community edtion for the first time and have one problem with the issue managment integration.
I like to add our mantis installtion to klaros. So i added it at the klaros configuration and klaros tells me that everthing is fine. after that i added a project and assigned the mantis entry to my project and saved it.
i defined some test cases and tried these to execute. if i want to track one of these test cases as an issue to mantis, klaros shows the message that no issue management system is assigned to the project. but it is assigned.
i dont know what to do?
klaros community edition 4.3.4
mantis 1.2.17
thanks for help!
mantis 1.2.17
thanks for help!
Hello Kevin,
This might be a regression in the refresh code for the test runner.
Does the problem persist if you first try to add an issue via Evaluate / Issues / New before running the test?
RE: Problem with issue management system - Mantis (Antwort)
Hello Kevin,
this issue should be fixed now in the 4.3.5 release. Thanks for reporting!
